SPI instead of SHIFTOUT - MAX7219
Results 1 to 12 of 12
    Mar 2007
    Default SPI instead of SHIFTOUT - MAX7219
    With SSPM3:0 = 0011, it specifies the SSP clock comes from Timer2/2. But you haven't set-up Timer2.
    Since the MAX7219 is a 10mhz device, you can run it at the highest speed available from the PIC.
    SSPM3:0 = 0000 -- SPI master mode, clock = FOSC/4
    Many thanks Darrel Taylor.
    Yes, you are right that's a mistake I have made. I wanted to have SSPM3:0 = 0010, i.e. the lowest speed.
    And I think CKE should be 1.
    I am not that far, I will check this later on.
    In the Main loop, you need to wait for the SSP to finish sending the last byte, before putting a new one in the buffer.
        toggle PORTB.0 ' to see if something is happening
        SSPBUF = "A" ' write to SSPBUF to start clock
        WHILE !SSPIF : WEND
        SSPIF = 0
    If I add this while end loop the PIC stops and never gets further. the PORTB.0 is not blinking any more (check with a scope connected to PORTB.0).
    It seems I have a problem with the interrupt setting the SSPIF flag never gets set.
    What I did in my code is:
    INTCON = %11000000       ' Set the interrupts, i.e. enable GIE and PEIE
    SSPIE = 1                       ' Enable SSPIE interrupt
    Is there any mistake I have overlooked in my interrupts setting?
    Also the MAX7219 needs a Latch(Load) signal from the PIC, to latch the last 16-bit's into the device. Since you're only sending 1 byte, I guess you just haven't made it that far yet though.
    Yes, you are right, I am not that far in the programming. I am adopting rather a pragmatic approach, i.e. doing things step by step.
    Thanks a lot.
    Quote Originally Posted by Momboz View Post
    NO! You don't want to do that.
    You just use the flag to tell when the SSP is finished.
    If you enable interrupts without any interrupt Handlers, it goes off into never never land, overflows Stacks and generally just doesn't work.
    Mar 2007
    Sorry DT
    I wasn't complete in my previous answer.
    The first thing I did was to test with the addition of the while loop as you proposed and it wasn't successful, i.e. No toggle on PORTB.0 signal. It looks like the While loop is blocking the process (or like SSPIF is never set). if I suppress the while loop the PORTB.0 will toggle again.
    That's the reason why I thought about setting the interrupts.
    Here is some sample code from meLabs. Maybe that would be of help to you.
    http://www.melabs.com/resources/samples/pbp/spimast.bas
    http://www.melabs.com/resources/samp...p/spislave.bas
    Tim Barr
    Mar 2007
    Quote Originally Posted by falingtrea View Post
    @falingtrea
    Many thanks for the advice. I have seen these examples and I couldn't succeed since I need a peer to talk to via the SPI. I am intending just to drive a MAX7219.
    Vielen Dank nochmals.
    Works fine here.
    Ran your program (with the suggested changes) on an 877, and It sends data from the SSP and blinks the LED.
    It's A VERY FAST blink. Not visible to the naked eye (or clothed ones).
    Try putting a PAUSE 200 in the Main Loop.
    Mar 2007
    Smile SPI instead of SHIFTOUT - MAX7219
    Works fine here.
    Dear DT
    I would like, first, to thank you very very much for your support and then I wish to give you a feedback on how far I went with my SPI interface.
    After some investigation I could find the reason of the problem I have making SPI running on my board. It is a hardware issue. It's the way I am using the Melabs PICPROTO-USB board. That doesn't mean that Melabs PICPROTO-USB board is faulty.
    On that board you have the possibility to use the USB board in high speed. Therefore you need a capacitor C7 (0.470 µF) as shown in the documentation of that Melabs board (http://www.melabs.com/downloads/ppusbsch_06.pdf). This seems to prevent the SPI interface for running properly. I have taken the C7 away and everything went fine with SPI interface.
    Maybe we will have a new Melabs board with a jumper that could leave this capacitor out when using the SPI interface
    For the time being I have to make a choice for by Melabs board usage: either using USB high speed (and put the C7 capacitor) or using SPI (and take away the capacitor).
    Once again many thanks for your help.
    Best wishes / Momboz
    Good find Momboz!
    I see you mentioned the PICPROTO-USB up in post #3.
    But I never even looked at the schematic.
    If you're using a PIC with USB, the SPI interface will be on different pins, so it shouldn't be a problem.
    But you're right. meLabs should have put a jumper in there for the capacitor.
    Cheers!
  1. Max7219 cascading problem ?
    By iugmoh in forum General
    Last Post: - 13th December 2020, 11:53
  2. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  3. Smart Star (how to use shift registers)
    By mackrackit in forum Code Examples
    Last Post: - 30th November 2008, 21:06
  4. Shorter Subroutines for MAX7219
    By exelanoz in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 12:35
  5. Replace Shiftout with spi
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 7th January 2007, 17:57
