compiler help!!!!
Results 1 to 10 of 10
    Quote Originally Posted by MINHLE View Post
    I have a problem with compiler.
    here how it look like (using MicroCode studio and MElabs programmer):
    when pressing button 'compiler'
    - searching for PICbacsic folder .... (end up nothing!)
    I scanned through PICbasic forum, and saw that the Oscillator should be right checked. reading the data sheet of 16f628, sec 14.2 oscillator. I found several ways of design( depend on user...). I cannot read or understand the circuit (USB programmer) it is too small.
    so some one can help me out of this trouble.
    anther thing is that: on the help/.about: "compiler is not installed". but I searched and found out that PICBASIC pro in the direction of melabs and Mechanics....
    I aslo try to install new compiler i.e. winpicprog and followed some instruction from this forum site. but I did not get any new result.
    thank for your guide,
    Minh le
    MicroCode Studio - Editor environment (like a souped up version of Windows NotePad, but so much more) - create/edit a file to be compiled by ->>>
    PicBasicPro - Compiler - translates 'verbal' commands into macros/text for assembly by ->>>
    MPLAB/MPASM - Assembler - assembles compiled code into a hex file for use by a programmer such as ->>>
    Microchip PICKIT2 - Programmer - connects thru the USB port to the PIC to program said PIC to run programs on hardware such as ->>>
    Whatever you've built or bought....
    So, as you can see, MCS can't find PicBasicPro because apparently you haven't bought and/or installed it yet...
    EDIT:
    WinPicProg - not a compiler, only a program to transfer HEX data (PIC program) from the PC to a PIC via a PIC programmer.
    MELabs programmer - PIC Programmer (similar to Microchip PICKIT2, performs same basic functions)
    Looking for a freebie or what? 5-fingered discount? Large ZIP file transfer?
    Not gonna happen here bud...
    Angry
    Skimask, take a deep breathe.... sit back and relax. Life is so short...
    Apr 2008
    Default thanks
    Hi Steve,
    thanks for your redirecting me to the webpage. I read that before. when I bought the USB programmer hardware they (advertiser on the web) did not mention about compiler so I though I buy then it works!!!!
    when receiving the package and installed it. there something missing: editor page and compiler....
    it cost too much to send a package (<10gram) from uSA to CAnada (40$: shipping from seller (20$) +Post Canada 20$)
    I am new in the firmware so everything begins from zero!!!
    I will try to contact the vendor later.
    thanks
    Minhle
    in montreal there are some places to sell it?
    The closest place from Montréal i know is located at the west-end of Canada. Their pricing is almost the same, bit bit much.
    Shipping from USA to Canada is ~20 bucks, depending the method you're using.
    Apr 2008
    Default your reply
    thanks Steve, should you send me that email or website, or phone?
    thanks again
    Minh Le
    Click on one of those bellow.
    1. USA
    2. Canada
  1. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 07:14
  2. Compiler refuses to compile
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 21st June 2008, 19:41
  3. How can I update my compiler 2.46 to 2.47 ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 12:35
  4. fastest and best compiler
    By toalan in forum Off Topic
    Last Post: - 3rd November 2005, 18:31
  5. Compiler Error
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 6th November 2003, 18:53
