USB to COM converter
Results 1 to 8 of 8
    Question USB to COM converter
    Hi all,
    after I finished our USBMOUSE and USBKeyboard successfully , I try to make usb to com converter so I try USBCDC emulator example , so now I can send from usb to com but I can't recive from COM to our usb so I think there is wrong in Hserin section, if anyone have hint to help me
    here is my code , I use PIC18F4455 with 20MHZ crystal , at baud rate 9600bps
    ' Pic Configuration
    asm
    __CONFIG _CONFIG1L, _USBDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _PLLDIV_5_1L
    __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_ON_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
    DEFINE OSC 48
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    ' USB module
    UCFG var byte EXT ' include UCFG register... Yeah Melabs didn't (
    ucfg = %00010100 ' enable internal USB pull-up, Full speed USB
    ' ANALOG I/O CONFIG
    ADCON1 = 15 ' Set all I/Os to Digital
    CMCON = 7 ' Disable Comparator
    Buffer VAR BYTE[8]
    Cnt VAR BYTE
    B0 VAR BYTE
    INT_LIST macro ; IntSource,Label,Type,ResetFlag?
    INT_Handler RX_INT,_SendUsB,PBP,yes
    INT_ENABLE RX_INT ; enable external (RX) interrupts
    USBInit
    ' Main Program Loop
    MainLoop:
    USBService ' Must service USB regularly
    Cnt = 8
    USBIn 3, Buffer, Cnt, MainLoop
    HSEROUT [STR Buffer\Cnt]
    GOTO Mainloop
    '---[RX_INT - interrupt handler]------------------------------------------------
    ' PROGRAM COMES HERE WHEN DATA ENTERS THE USART PORT
    SendUsB:
    HSERIN [B0]
    Buffer[0] = b0
    cnt = 1
    OutLoop:
    USBOut 3, Buffer, Cnt, OutLoop
    @ INT_RETURN
    Quote Originally Posted by iugmoh View Post
    HSERIN [B0]
    Buffer[0] = b0
    You HSERIN, but how do you know anything is actually there?
    How do you know that your connections are is good?
    Or that your sending device is working properly?
    I make a new code to test hserin and hserout , I noted that Hserout working weill but HSERIN not getting any data, I sure that the connection is true but I think that there thing error in code , I don't know
    here is my code:
    ' Pic Configuration
    asm
    __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L
    __CONFIG _CONFIG5H, _CPB_ON_5H
    endasm
    DEFINE OSC 48
    ' USB module
    ' ANALOG I/O CONFIG
    Buffer VAR BYTE[8]
    Cnt VAR BYTE
    B0 VAR BYTE
    output portb.0
    high portb.0
    low portb.0
    ' Main Program Loop
    MainLoop:
    HSERIN 1000,goo,[B0]
    high portb.0
    goo:
    HSEROUT ["send"]
    GOTO Mainloop
    did you tried without any USB?
    It always rolls right back to the basics...doesn't it...
    nope.. i haven't talked about led blink yet
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. serial to usb converter
    By nicjo in forum Serial
    Last Post: - 18th September 2008, 00:52
  4. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
  5. Serial to USB converter
    By jrt4fun in forum USB
    Last Post: - 8th August 2005, 16:14
