compiler help!!!!
Results 1 to 10 of 10
    Apr 2008
    Angry compiler help!!!!
    I have a problem with compiler.
    here how it look like (using MicroCode studio and MElabs programmer):
    when pressing button 'compiler'
    - searching for PICbacsic folder .... (end up nothing!)
    I scanned through PICbasic forum, and saw that the Oscillator should be right checked. reading the data sheet of 16f628, sec 14.2 oscillator. I found several ways of design( depend on user...). I cannot read or understand the circuit (USB programmer) it is too small.
    so some one can help me out of this trouble.
    anther thing is that: on the help/.about: "compiler is not installed". but I searched and found out that PICBASIC pro in the direction of melabs and Mechanics....
    I aslo try to install new compiler i.e. winpicprog and followed some instruction from this forum site. but I did not get any new result.
    thank for your guide,
    Minh le
    Quote Originally Posted by MINHLE View Post
    Minh le
    MicroCode Studio - Editor environment (like a souped up version of Windows NotePad, but so much more) - create/edit a file to be compiled by ->>>
    PicBasicPro - Compiler - translates 'verbal' commands into macros/text for assembly by ->>>
    MPLAB/MPASM - Assembler - assembles compiled code into a hex file for use by a programmer such as ->>>
    Microchip PICKIT2 - Programmer - connects thru the USB port to the PIC to program said PIC to run programs on hardware such as ->>>
    Whatever you've built or bought....
    So, as you can see, MCS can't find PicBasicPro because apparently you haven't bought and/or installed it yet...
    EDIT:
    WinPicProg - not a compiler, only a program to transfer HEX data (PIC program) from the PC to a PIC via a PIC programmer.
    MELabs programmer - PIC Programmer (similar to Microchip PICKIT2, performs same basic functions)
    Looking for a freebie or what? 5-fingered discount? Large ZIP file transfer?
    Not gonna happen here bud...
    Angry
    Skimask, take a deep breathe.... sit back and relax. Life is so short...
    Apr 2008
    Default thanks
    Hi Steve,
    thanks for your redirecting me to the webpage. I read that before. when I bought the USB programmer hardware they (advertiser on the web) did not mention about compiler so I though I buy then it works!!!!
    when receiving the package and installed it. there something missing: editor page and compiler....
    it cost too much to send a package (<10gram) from uSA to CAnada (40$: shipping from seller (20$) +Post Canada 20$)
    I am new in the firmware so everything begins from zero!!!
    I will try to contact the vendor later.
    thanks
    Minhle
    in montreal there are some places to sell it?
    The closest place from Montréal i know is located at the west-end of Canada. Their pricing is almost the same, bit bit much.
    Shipping from USA to Canada is ~20 bucks, depending the method you're using.
  1. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 07:14
  2. Compiler refuses to compile
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 21st June 2008, 19:41
  3. How can I update my compiler 2.46 to 2.47 ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 12:35
  4. fastest and best compiler
    By toalan in forum Off Topic
    Last Post: - 3rd November 2005, 18:31
  5. Compiler Error
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 6th November 2003, 18:53
