Bitwise operations and masks: basics, help?
Results 1 to 12 of 12
    Yes i see some different ways, just paste your pattern here and where to send them, i'll give you something to think about.
    xnihilo's Avatar
    xnihilo Guest
    Smile Bits replacement
    Example:
    The bits I need to set to display the "0" digit on the 7 segments display are:
    on porta: %***01* , all other bits are left untouched
    on portc: %*11111 , bit 5 is left untouched.
    I have two arrays of bytes:
    cval VAR BYTE[10] and aval VAR BYTE[10], each index represents a duet of bytes containing the bits configuration to display a digit.
    arrays index 0 for digit "0",... up to digit "9" in index 9.
    I only need to 'insert' chunks of bits in porta and portc registers.
    For a given array index (representing the 7 bits to make a digit):
    For porta I will need to replace bits 1 and 2 from porta by bits 1 and 2 from aval variable.
    For portc I will need to replace bits 4 to 0 from portc by bits 4 to 0 from cval variable
    is this clear ???
    Why not a WORD array instead? Anyways, yes it's clear enough. I'll do something a little bit later.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Yes, I may use a WORD array instead... Anyway, it wont be much different I guess. The principle of bit manipulations will remain the same I beleive...
    Anyway, thank you very much for your help.
            '   Tested on 16F877
    @       __CONFIG _XT_OSC & _LVP_OFF & _WDT_OFF
            TRISA=0
            TRISB=0
            TRISC=0
            TRISD=0
            Aval VAR byte [10]
            Cval VAR BYTE [10]
            CounterA VAR BYTE
            CounterB VAR BYTE
            PORTA=0
            PORTB=0
            PORTC=0
            PORTD=0
            ADCON1=7
            AVAL[0]=%00000000
            AVAL[1]=%00000010
            AVAL[2]=%00000100
            AVAL[3]=%00001010
            AVAL[4]=%00010000
            AVAL[5]=%00100010
            AVAL[6]=%01000100
            AVAL[7]=%10000010
            AVAL[8]=%10101001
            AVAL[9]=%11111111
            CVAL[0]=%00000000
            Cval[1]=%00000001
            CVAL[2]=%00000010
            CVAL[3]=%00000100
            CVAL[4]=%00001000
            CVAL[5]=%00010000
            CVAL[6]=%00101000
            CVAL[7]=%01000100
            CVAL[8]=%10000010
            CVAL[9]=%11100001
    Start:
            for CounterB = 0 to 255
                PORTA=CounterB
                PORTB=COUNTERB
                PORTC=CounterB
                PORTD=COUNTERB
                fOR CounterA = 0 TO 9
                    '   this should be the section you need
                    PORTA = (PORTA & %11111001) | (AVAL[COUNTERA] & %00000110)
                    PORTC = (PORTC & %11100000) | (CvAL[CounterA] & %00011111)
                    PAUSE 250
                    NEXT
                NEXT
            STOP
    PS: As you only use 7 bit... you could also us ONLY 1 byte array instead of 2.
    What I would do is:
    PORTC = PORTC & %11100000   / Clear all the bits in PORTC that are segments
    PORTC = AVAL[x] | PORTC        / sets the bits in PORTC that are '1' in AVAL[x]
    PORTA = PORTA & %11111001  /  Clear all the bits in PORTA that are segments
    PORTA = CVAL[x] | PORTA       / sets the bits in PORTA that are '1' in CVAL[x]
    if you just want to use one matrix for segment data you can do this:
    ORMASK = SEGVAL[x] & %00011111 / makes sure only 5 lsb of SEGVAL[x] '1' bits get set below
    PORTC = ORMASK | PORTC         / sets the bits in PORTC that are '1' in AVAL[x]
    ORMASK = SEGVAL[x] >> 4         / shift data 4 to right to position correct SEGVAL[x] bits for PORTA
    ORMASK = ORMASK & %0000110 / makes sure only 2 bits of SEGVAL[x] '1' bits get set below
    PORTA = PORTA | %11111001    / Clear all the bits in PORTA that are segments
    PORTA = ORMASK | PORTA        / sets the bits in PORTC that are '1' in AVAL[x]
    Tim Barr
    Yup, mine is just in case something is badly define in the array, unless
    PORTA = (PORTA & %11111001) | AVAL[COUNTERA]
    PORTC = (PORTC & %11100000) | CvAL[CounterA]
    Would work anyways.
