Hello,
Simple?
Not so simple because each digit on the 7segments display needs (in my design) a pair of bytes for porta and portc that are found in a 10 entries array, and I prefer not to use intermediate variable.
Sorry but I didn't understand your example above:
portc: x11111
PORTC=PORTC | %00011111
porta: xxxx10x,
let's say porta value is %00011001 and I need to alter only bits 1 and 2 with the following pattern stored in a BYTE varible called "avar":
variable avar value is %-----10-
Can I isolate a chunk of a byte and insert it at a desired position in anoter byte?
