PIC backup power supply: switchover ???
Results 1 to 14 of 14
    Quote Originally Posted by xnihilo View Post
    Skimask, the "crazy flying tiger"...
    I need some power supply in the mag while it is out of the gun, it cannot sleep because player interacts with the pic inside the mag while it is away from the main power supply. See?
    So don't sleep! Sounds to me like the 'mag' is going to be fairly simple anyways. It'll take a LONG time to deplete a few AAA batts.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    ->Who is talking about depleting batteries? It is only for a short time (while the mag is pulled out and reinserted a few seconds later) and during this time, the PIC in the mag has to continue running.
    Let me explain, when I'm talking about BACKUP it is not like the one for the CMOS in a PC.
    I need to switch temporarily from a supply from the GUN (good battery with a voltage regulator) to another one (3 mini batteries onboard the mag).
    The mag still needs to run when I remove it from the gun unit. I want to use small wristwatch batteries to supply power to the mag while it is out of the mag.
    Do you understand?
    By the way, mag is not simple at all, the managment of this little ******* fills all the 1048 words of the PIC...
    ->Who is talking about depleting batteries? It is only for a short time (while the mag is pulled out and reinserted a few seconds later) and during this time, the PIC in the mag has to continue running................
    Yes, I get it... And again, how much power do you think a PIC uses just sitting there? Just use the blocking diode and those watch batteries. It'll take awhile to drain those out and if you're careful, it could take QUITE AWHILE to drain them out.
    And as far as how simple the 'mag' is...it doesn't matter if the PIC is empty or full, it's still going to draw the same current. It's sounds fairly simple to me...
    Either the mag really is just that simple, or you're making it entirely too complicated.
    But then again, I'm not trying to zap or fry anybody either...
  1. Backup Power Supply
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 20:37
  2. Ideal backup power for PIC micro
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 01:07
  3. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  4. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
  5. backup supply for pic
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 14th May 2006, 18:24
