My method for the backup is 'simple'-ish. Used it a number of times, works for me...Don't worry, way to complicated....
+5v normally powers the whole circuit except for the PIC. It also trickle charges a 3 cell pack of NiMH batt's thru a blocking diode and a current limiting resistor (I also have a jumper that adds another resistor in parallel if I need to do a manual fast charge for awhile, i.e. I let it run too long on backup). This 3 cell pack directly feeds the PIC. I tap off the main +5v line into a normal port and keep an eye on it. If I lose the main +5v line, I shut down other peripherals, drop the clock speed, and start napping until main power comes back up. A single PIC running off 3 AAA 650 mAh NiMH cells can run a long time in sleep / low power mode. Even looping on the internal low speed clock (~37Khz) draws so little current that the thing can 'sleep' for a solid week before I have to worry about.
