Bitwise operations and masks: basics, help?
Results 1 to 12 of 12
    xnihilo's Avatar
    xnihilo Guest
    Smile Bitwise operations and masks: basics, help?
    I know there are the bitwise operators to work at bit level. I'm not familiar with these and logic was never my strong point. That's why I would need some help here.
    I'm using a 7 segments led display (plus a dot, which makes 8 leds, and two ground pins, for a total of 10 pins).
    Each segment is a led. The 7 sements (plus the dot led) have common cathode.
    Each led anode is connected to a pin of a PIC16F684. So to turn on a segment, I just need to output 5V on the appropriate pin. To display a digit, I just have to turn on the appropriate pins/segments/leds.
    I'm using RC4 to RC0 for 5 of the 7 segments (segments a to e) and RA1 to RA2 for the 2 last segments (f, g) (while the "dp" dot is on RA0).
    I have to set the appropriate pins to display the adequate segments to display a digit.
    For example, to display digit "0", I need to turn on the pins that will light the segments a, b, c,d, d, e, f, thus, for my design, the pins RC4 to RC0 and RA1. (a little complicated, yes).
    Anyway, I have to set portA and portC to:
    porta: xxxx10x, portc: x11111
    where the "x" represent bits that must not be changed.
    How can I replace the needed bits without changing the "x" bits?
    I guess I should use bits mask but what is the magic?
    Thanks for any help here.
    Regards.
    when you want to clear a bit you use AND, set a bit OR
    portc: x11111
    PORTC=PORTC | %00011111
    <hr>
    porta: xxxx10x,
    for this one you may also do it simple..
    TempVar=PORTA
    TempVar.1=0
    TempVar.2=1
    PORTA=TempVar
    OR, in some case, the following will work without much problem
    PORTA.1=0
    PORTA.2=1
    HTH
    xnihilo's Avatar
    xnihilo Guest
    Smile
    portc: x11111
    <hr>
    porta: xxxx10x,
    TempVar=PORTA
    TempVar.1=0
    TempVar.2=1
    PORTA=TempVar
    PORTA.1=0
    PORTA.2=1
    HTH
    Hello,
    Simple?
    Not so simple because each digit on the 7segments display needs (in my design) a pair of bytes for porta and portc that are found in a 10 entries array, and I prefer not to use intermediate variable.
    Sorry but I didn't understand your example above:
    portc: x11111
    porta: xxxx10x,
    let's say porta value is %00011001 and I need to alter only bits 1 and 2 with the following pattern stored in a BYTE varible called "avar":
    variable avar value is %-----10-
    Can I isolate a chunk of a byte and insert it at a desired position in anoter byte?
    Yes i see some different ways, just paste your pattern here and where to send them, i'll give you something to think about.
    xnihilo's Avatar
    xnihilo Guest
    Smile Bits replacement
    Example:
    The bits I need to set to display the "0" digit on the 7 segments display are:
    on porta: %***01* , all other bits are left untouched
    on portc: %*11111 , bit 5 is left untouched.
    I have two arrays of bytes:
    cval VAR BYTE[10] and aval VAR BYTE[10], each index represents a duet of bytes containing the bits configuration to display a digit.
    arrays index 0 for digit "0",... up to digit "9" in index 9.
    I only need to 'insert' chunks of bits in porta and portc registers.
    For a given array index (representing the 7 bits to make a digit):
    For porta I will need to replace bits 1 and 2 from porta by bits 1 and 2 from aval variable.
    For portc I will need to replace bits 4 to 0 from portc by bits 4 to 0 from cval variable
    is this clear ???
    Why not a WORD array instead? Anyways, yes it's clear enough. I'll do something a little bit later.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Yes, I may use a WORD array instead... Anyway, it wont be much different I guess. The principle of bit manipulations will remain the same I beleive...
    Anyway, thank you very much for your help.
            '   Tested on 16F877
    @       __CONFIG _XT_OSC & _LVP_OFF & _WDT_OFF
            TRISA=0
            TRISB=0
            TRISC=0
            TRISD=0
            Aval VAR byte [10]
            Cval VAR BYTE [10]
            CounterA VAR BYTE
            CounterB VAR BYTE
            PORTA=0
            PORTB=0
            PORTC=0
            PORTD=0
            ADCON1=7
            AVAL[0]=%00000000
            AVAL[1]=%00000010
            AVAL[2]=%00000100
            AVAL[3]=%00001010
            AVAL[4]=%00010000
            AVAL[5]=%00100010
            AVAL[6]=%01000100
            AVAL[7]=%10000010
            AVAL[8]=%10101001
            AVAL[9]=%11111111
            CVAL[0]=%00000000
            Cval[1]=%00000001
            CVAL[2]=%00000010
            CVAL[3]=%00000100
            CVAL[4]=%00001000
            CVAL[5]=%00010000
            CVAL[6]=%00101000
            CVAL[7]=%01000100
            CVAL[8]=%10000010
            CVAL[9]=%11100001
    Start:
            for CounterB = 0 to 255
                PORTA=CounterB
                PORTB=COUNTERB
                PORTC=CounterB
                PORTD=COUNTERB
                fOR CounterA = 0 TO 9
                    '   this should be the section you need
                    PORTA = (PORTA & %11111001) | (AVAL[COUNTERA] & %00000110)
                    PORTC = (PORTC & %11100000) | (CvAL[CounterA] & %00011111)
                    PAUSE 250
                    NEXT
                NEXT
            STOP
    PS: As you only use 7 bit... you could also us ONLY 1 byte array instead of 2.
    What I would do is:
    PORTC = PORTC & %11100000   / Clear all the bits in PORTC that are segments
    PORTC = AVAL[x] | PORTC        / sets the bits in PORTC that are '1' in AVAL[x]
    PORTA = PORTA & %11111001  /  Clear all the bits in PORTA that are segments
    PORTA = CVAL[x] | PORTA       / sets the bits in PORTA that are '1' in CVAL[x]
    if you just want to use one matrix for segment data you can do this:
    ORMASK = SEGVAL[x] & %00011111 / makes sure only 5 lsb of SEGVAL[x] '1' bits get set below
    PORTC = ORMASK | PORTC         / sets the bits in PORTC that are '1' in AVAL[x]
    ORMASK = SEGVAL[x] >> 4         / shift data 4 to right to position correct SEGVAL[x] bits for PORTA
    ORMASK = ORMASK & %0000110 / makes sure only 2 bits of SEGVAL[x] '1' bits get set below
    PORTA = PORTA | %11111001    / Clear all the bits in PORTA that are segments
    PORTA = ORMASK | PORTA        / sets the bits in PORTC that are '1' in AVAL[x]
    Tim Barr
    Yup, mine is just in case something is badly define in the array, unless
    PORTA = (PORTA & %11111001) | AVAL[COUNTERA]
    PORTC = (PORTC & %11100000) | CvAL[CounterA]
    Would work anyways.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Hello,
    Thank you for this information.
    Bitwise operations are less simple than I thought but are necessary
    Nah not that complicated.. but once you get them they're pretty handy.
    http://en.wikipedia.org/wiki/Bitwise_operation
