SOUND makes LCD quit working
Results 1 to 4 of 4
    Default SOUND makes LCD quit working
    I am using PORT B to supply power to the LCD and generate a tone.
    In the code below, when the SOUND command executes, the LCD goes blank.
    If I comment out the SOUND command, the LCD stays on. What's going on?
    TRISC = %00000000
    TRISA = %101100
    TRISB = %10000000
    @ DEVICE pic16f689,wdt_off
    HIGH PORTB.4 'Turn on power to LCD
    Define LCD_DREG PORTC 'Set LCD data port
    DEFINE LCD_DBIT 0 'Set LCD starting data bit
    DEFINE LCD_RSREG PORTC 'Set LCD register select port
    DEFINE LCD_RSBIT 4 'Set LCD register select bit
    DEFINE LCD_EREG PORTC 'Set LCD enable port
    DEFINE LCD_EBIT 5 'Set LCD enable bit
    DEFINE LCD_BITS 4 'Set LCD bus size
    DEFINE LCD_LINES 2 'Set LCD number of lines
    OPTION_REG = %00111000
    ANSEL = 0
    CM1CON0 = %00000000
    LCDOUT $fe,1
    LCDOUT DEC 9999
    PAUSE 1000
    SOUND PORTB.6,[118,200]
    Thank you for your help.
    Feb 2005
    Essex, UK
    I'm not sure if that's your whole code or not. You should really have a small delay before your program starts to allow the Power supply to settle properly. There should also be a delay for the lcd to initialise properly before sending data to it. These are unlikely to be the cause of your problem but it's good practice. Try placing a PAUSE 500 before you send PORTB.4 high. 500ms delay before writing to the LCD should be enough time for the majority of LCDs to intialise correctly.
    When you say power the LCD from PORTB you're not talking about the backlight as well are you? The PIC pins can only supply 25mA and some LCDs can take a lot more than that to light.
    Just to check, PORTB.6 is not accidentally connected to one of the LCD pins is it?
    Cheers
    Rob
    at the end of your program, you should or finish by a STOP command or with an endless loop, unless your PIC may behave in a weird way.
    Here:   GOTO Here
    You may also need to check if ALL ADCs and comparators are disabled. Here i see 2 missing lines
    ANSELH = 0
    CM2CON0 = 0
    And then what you drive and how, may help us to go deeper in our understanding.
    HTH
    Thanks for the help! The ANSELH = 0 line fixed the problem! This is a small part of my program. As I use PORTC to control the LCD, it's a wonder this hasn't caused more problems before now. I thought I RTFDS enough, but apparently not! Thanks again.
  1. 2x16 lcd not working with pic16f72
    By vu2iia in forum Schematics
    Last Post: - 16th February 2011, 15:59
  2. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 06:41
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Simple LCD code not working..
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 28th April 2008, 14:55
  5. Need help with LCD number display.
