WRITE REAR eeprom Address ????'s
Results 1 to 3 of 3
    The way you do it right now write 20 time on the same EEPROM adress... well your eeprom wil wear out pretty fast huh?
    Anyways, several way, the first that spring to mind is..
    For EEPAddr=0 to 255
        for d = 0 to 20
            ADCIN 0, Value
            y = ( Value *100 ) / 51   'divided down from * 255 / 130
            LCDOUT 254,Row1,"LOG SENSOR ",DEC1 (y / 100 ),".",DEC2 ( y // 100 )," VDC"
            lcdout 254,Row3+2, "0......|......5"
            ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
            @         BARgraph  _Value,   2,   2,    15,   255,  lines
            next
        wriTE EEPAddr, Value
        next
    LCDOUT $FE,  1, "Thanks for shopping here",_
           $FE,$C0, "Come again :o)"
    HTH
    Jan 2007
    Houston, TX
    Good call on the Eeprom wearing out fast.
    Thanks for the help Mister E I will give it a try!
    Padawan-78
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
