Need help in code
Results 1 to 23 of 23
    camolas,
    Do you have a schematic you could post?
    Yes i have please see it. (i put 2 bottuns but with a good code one i think can do the jobe)
    Last edited by camolas; - 17th April 2008 at 23:51. Reason: forget te tell more things
    Talking
    Just solve it now and with only one pushbutton
    @ DEVICE pic16F877A, WDT_ON ' Watchdog Timer
    @ DEVICE pic16F877A, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F877A, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F877A, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F877A, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F877A, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877A, WRT_OFF ' Flash Memory Word Enable
    TRISB.0=1
    TRISC.7=0
    LED var PORTC.7
    Bot1 var PORTB.0
    CMCON=%00000111 ' Disable Comparators
    CVRCON=%00000000 ' Disable Reference Module
    OPTION_REG.7=0 ' Enable Weak Pull-Up's
    ini:
    Low LED
    WHILE Bot1=0 :WEND
    PAUSE 10000
    high LED
    PAUSE 300
    Low LED
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    Thanks you all
    Wink
    Hi, Camolas
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    Those two lines ( GOSUB FIM and FIM: ) can be simply wiped off : the only use is to loose two clock cycles ... say nothing for us.
    " Im Portugese next Europen winers cup"
    too much ... vinho verde ???
    Hi, Camolas
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    I will try that later.
    About the vinho verde not at all for the moment
    Thanks for the hellp Alain, when you came to Prtugal i will buy you a botle of vinho verde.
    Im from the city that mackes the bert Portugese vinho verde Casal Garcia, Aveleda...
    By by
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
