Need help in code
Results 1 to 23 of 23
    When you're using PM, you shouldn't need to bother with it. Just to confirm it, i just uncommented the one in a .INC file and write over them... no compilation errors for PM, and the config fuses are set as expected when i look them in my PIC Programmer software.
    If no OSC is defined, PBP will consider 4 MHz.. no big deal. Default XT fuses for PM is XT. it seems to have some activity, seems something work, i worry more about the program flow. I'm still trying to understand what the OP need to do
    Camolas, can you ask your question in your own language (i feel spanish) so maybe someone else here could help you to translate it for us (maybe google translation but )
    Hi again,
    Im Portugese next Europen winers cup (lol i hope)
    In Portugese:
    Pretendo controlar com um botao low pullup (ou mais se for necessario) um led da seguinte forma.
    -Quando o botao esta desligado demore 40s a acender o led e depois fique aceso durante 3s.
    Depois de apagado fique a espera de outro sinal (aqui podera ser um outro botao ou entao o mesmo quando fique no estado de ligado) e so volte a fazer a mesma rutina depois que o botao seja desligado led aceso.... ........
    Now more dificult in my best Inglish:
    I need to control a led with one low pullup pushbutton (or more if neded) to perform this tasck.
    -Wen pushbutton is not pressed tacks 40s then turn on led for 3s.
    So the led is now off then the code must whait for another signal ( i can use one more pushbutton or the same because e is on at this time) and then when this signal go to off e stars the rutine again, Wen pushbutton is not pressed tacks 40s then turn on led for 3s...
    Thanks all
    camolas,
    Do you have a schematic you could post?
    camolas,
    Yes i have please see it. (i put 2 bottuns but with a good code one i think can do the jobe)
    Last edited by camolas; - 17th April 2008 at 23:51. Reason: forget te tell more things
    Talking
    Just solve it now and with only one pushbutton
    @ DEVICE pic16F877A, WDT_ON ' Watchdog Timer
    @ DEVICE pic16F877A, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F877A, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F877A, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F877A, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F877A, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877A, WRT_OFF ' Flash Memory Word Enable
    TRISB.0=1
    TRISC.7=0
    LED var PORTC.7
    Bot1 var PORTB.0
    CMCON=%00000111 ' Disable Comparators
    CVRCON=%00000000 ' Disable Reference Module
    OPTION_REG.7=0 ' Enable Weak Pull-Up's
    ini:
    Low LED
    WHILE Bot1=0 :WEND
    PAUSE 10000
    high LED
    PAUSE 300
    Low LED
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    Thanks you all
    Wink
    Hi, Camolas
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    Those two lines ( GOSUB FIM and FIM: ) can be simply wiped off : the only use is to loose two clock cycles ... say nothing for us.
    " Im Portugese next Europen winers cup"
    too much ... vinho verde ???
    Hi, Camolas
    GOSUB FIM
    FIM:
    WHILE Bot1=1 :WEND
    GOTO ini
    I will try that later.
    About the vinho verde not at all for the moment
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
