By the way ...
Think ICD2 is the most powerful and will allow 16 and 32 Bits ICSP Pics programming AND Debugging with MPLAB ...
Only 8 bits with The PicFlash ... and no PbP debugging.
But cost is also different !!!
By the way ...
This also explains ICSP. http://ww1.microchip.com/downloads/e...Doc/51553E.pdf
You can also adapt you PICSTART into a ICSP. I use 6x1 headers that match the PICKIT2 on the PCB. Make the adapter DIP to cable for the PICSTART , use MCLR, ICSPDAT, ICSPCLK, and VSS from the PICKSTART. Power is provided at the PCB.
FOLLOW ALL OF THE ISOLATION GUIDELINES
Now you can use a PICKIT2 or the PICSTART.
My PICKSTART stays on the bench and my PICKIT goes on the road.
Thats my two cents![]()
Thank you Dave.
Do I need the PICKIT2 to adapt the PICSTART into an ICSP?
Koossa
No, sorry I made it confusing.
All you need are the 4 wires from the PICSTART to the chip. Plus power at the chip.
You may want to read this.
http://www.picbasic.co.uk/forum/show...2&postcount=25
maybe this one too
http://www.auelectronics.com/Q8.htm
