In-circuit Programming.
Results 1 to 15 of 15
    So,
    ICD2 from Microchip
    PicFlash2 from Mikroelektronika ...
    are the ones I would recommend.
    Thank you very much!!
    Do I need any modifications on my circuit if I move over to in-circuit programming?
    Lightbulb
    The ICSP used pins must be disabled from your circuitry just for programming ... you re-enable those PCB tracks after programming by using jumpers or, simpler by tin drops on the PCB side.
    see here :
    http://www.mikroe.com/pdf/picflash_manual_v5.pdf
    It's the clearest document I know ...
    I really appreciate it!
    Lightbulb
    By the way ...
    Think ICD2 is the most powerful and will allow 16 and 32 Bits ICSP Pics programming AND Debugging with MPLAB ...
    Only 8 bits with The PicFlash ... and no PbP debugging.
    But cost is also different !!!
    Will I be able to do PbP debugging with the ICD2?
    This also explains ICSP. http://ww1.microchip.com/downloads/e...Doc/51553E.pdf
    You can also adapt you PICSTART into a ICSP. I use 6x1 headers that match the PICKIT2 on the PCB. Make the adapter DIP to cable for the PICSTART , use MCLR, ICSPDAT, ICSPCLK, and VSS from the PICKSTART. Power is provided at the PCB.
    FOLLOW ALL OF THE ISOLATION GUIDELINES
    Now you can use a PICKIT2 or the PICSTART.
    My PICKSTART stays on the bench and my PICKIT goes on the road.
    Thats my two cents
    Thank you Dave.
    Do I need the PICKIT2 to adapt the PICSTART into an ICSP?
    Koossa
  1. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  2. Replies: 3
    Last Post: - 29th October 2006, 10:16
  3. In circuit GANG programming?
    By dhouston in forum General
    Last Post: - 13th February 2006, 01:43
  4. In circuit serial programming
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 17th February 2005, 16:08
  5. programming PICs in circuit
    By peterdeco1 in forum Off Topic
    Last Post: - 12th October 2004, 14:48
