In-circuit Programming.
Results 1 to 15 of 15
    Default In-circuit Programming.
    Good day Picers
    I have always done my programming with the Microchip picstart plus for DIP PICs.
    I want to do In-circuit programming on SMD PICs now.
    What are the best options?
    I see Microchip have a "MPLAB REAL ICE" and the "MPLAB ICD 2".
    Are these the best programmers to use and what else do I need.
    Do I need any changes on my circuit side?
    Thank you
    Koossa
    Hi, Koossa
    Depends on the pinouts you use ... but 3M builds "pinthrough" test chip carriers for SMD devices ... just build an adaptator to suit you need. ( to buy from Farnell i.e.)
    Microchip also sells ready to use adaptators ...
    Thank you for your reply.
    I want to program my SMD Pic while it is in the circuit.
    I'm not that clued up with this stuff, but what will the adaptor do?
    So,
    ICD2 from Microchip
    PicFlash2 from Mikroelektronika ...
    are the ones I would recommend.
    Thank you very much!!
    Do I need any modifications on my circuit if I move over to in-circuit programming?
    Lightbulb
    The ICSP used pins must be disabled from your circuitry just for programming ... you re-enable those PCB tracks after programming by using jumpers or, simpler by tin drops on the PCB side.
    see here :
    http://www.mikroe.com/pdf/picflash_manual_v5.pdf
    It's the clearest document I know ...
    I really appreciate it!
    Lightbulb
    By the way ...
    Think ICD2 is the most powerful and will allow 16 and 32 Bits ICSP Pics programming AND Debugging with MPLAB ...
    Only 8 bits with The PicFlash ... and no PbP debugging.
    But cost is also different !!!
    Will I be able to do PbP debugging with the ICD2?
    This also explains ICSP. http://ww1.microchip.com/downloads/e...Doc/51553E.pdf
    You can also adapt you PICSTART into a ICSP. I use 6x1 headers that match the PICKIT2 on the PCB. Make the adapter DIP to cable for the PICSTART , use MCLR, ICSPDAT, ICSPCLK, and VSS from the PICKSTART. Power is provided at the PCB.
    FOLLOW ALL OF THE ISOLATION GUIDELINES
    Now you can use a PICKIT2 or the PICSTART.
    My PICKSTART stays on the bench and my PICKIT goes on the road.
    Thats my two cents
    Thank you Dave.
    Do I need the PICKIT2 to adapt the PICSTART into an ICSP?
    Koossa
    No, sorry I made it confusing.
    All you need are the 4 wires from the PICSTART to the chip. Plus power at the chip.
    Thanks a Lot!!!
  1. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  2. Replies: 3
    Last Post: - 29th October 2006, 10:16
  3. In circuit GANG programming?
    By dhouston in forum General
    Last Post: - 13th February 2006, 01:43
  4. In circuit serial programming
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 17th February 2005, 16:08
  5. programming PICs in circuit
    By peterdeco1 in forum Off Topic
    Last Post: - 12th October 2004, 14:48
