So what exactly are you looking for? A completed PCB based off the PICPROTO18 capable of driving 8 servos?
skimask,
I already have the PICproto 18 board w/ chip carrier, volt reg., caps, crystal, etc. mounted on it.
I also have a schematic for the 8 servo controller.
What I was hoping for was some pictures showing trace work (using bare bar wire) on any of the PICprotoboard(s) that others have made, so I can get an idea of the most efficient (as well as clean, neat, organized) way of mounting/connecting components on the "proto" area of these boards (as Darrel has stated below) rather than a rats nest of jumper wires going everywhere.
I've built alot of circuits in the past on perf board, Vector board, wire wrapped, plastic breadboarded, etc. but the cleanest method I've used is like the stripboards on a site called winpicprog. Too bad the proto area of the PICproto boards weren't set up this (strip) way.
