PICPROTO 18 Prototyping Board Examples
Results 1 to 10 of 10
    Apr 2008
    Default PICPROTO 18 Prototyping Board Examples
    Hello Everyone,
    I'm a new member to this forum.
    I am currently in the process of building a control board for an 8 servo biped walker using the PICPROTO 18 Prototyping Board.
    Does anyone have any pictures or diagrams of their trace work and parts placement for any of the PICPROTO 18 board(s) they made ? Doesn't matter what the board was designed to do. (Note: The parts placement/tracework/schematic, etc. for the IC, regulator, caps, crystal etc. is already given w/ the sheet that comes with the board, so I'm not looking for that) or know where I can find some examples ?
    I was hoping to lay down (solder) bar wire for the "traces" rather than run, jumper a bunch of insulated wire (spagetti) all over the place.
    Thanks !,
    Rick
    Quote Originally Posted by rick hardy View Post
    So what exactly are you looking for? A completed PCB based off the PICPROTO18 capable of driving 8 servos?
    Being that he said...
    I don't think that's the case skimask.
    I'm sure he's looking for the most efficient ways to mount/connect components on that particular proto-board.
    Ever use a PICPROTO 18?
    Default Picproto18
    I'd be curious to see examples too.
    Datasheet: http://microengineeringlabs.com/downloads/pp18_06.pdf
    Apr 2008
    skimask,
    I already have the PICproto 18 board w/ chip carrier, volt reg., caps, crystal, etc. mounted on it.
    I also have a schematic for the 8 servo controller.
    What I was hoping for was some pictures showing trace work (using bare bar wire) on any of the PICprotoboard(s) that others have made, so I can get an idea of the most efficient (as well as clean, neat, organized) way of mounting/connecting components on the "proto" area of these boards (as Darrel has stated below) rather than a rats nest of jumper wires going everywhere.
    I've built alot of circuits in the past on perf board, Vector board, wire wrapped, plastic breadboarded, etc. but the cleanest method I've used is like the stripboards on a site called winpicprog. Too bad the proto area of the PICproto boards weren't set up this (strip) way.
    skimask,
    I already have the PICproto 18 board w/ chip carrier, volt reg., caps, crystal, etc. mounted on it.............rather than a rats nest of jumper wires going everywhere.
    Ah...I smell what you're cooking...
    I think that I was thinking about something like one of those '530 hole' 5-pad-per-strip things like from Radio Shack mounted on top of the PICProto18 vs. mounting everything on the PICProto18 itself, like with an multiple pin single in line connector at one end to get access to the PIC's pins.
    Oh...and I like rat's nests!!! Some of my 'finest' work!!!
    http://web.ndak.net/jdgrotte/mp3play...rpicsmain.html
    I never used any PICProto myself, but i found those
    http://images.google.ca/imgres?imgur...%3Den%26sa%3DX
    http://webs.lanset.com/rcochran/cm11a.html
    http://www.mcmanis.com/chuck/robotics/projects/ -- Check for The servo speed controller
    But yeah.. they are really simple and probably not exactly what you're looking for... on the other hand... that's the only one i found
    Default Prototyping techniques
    Here are two shots of a board I built for analysing hemoglobin oxygen absorption in blood. It is built on an Olimex P40 board with SMT resistors & caps on the underside. All the wiring is wire wrap wire soldered directly to underside of the board. There is a 16 bit ADC, Real Time Clock, LCD driver, variable amplitude LED drivers and a PIC16F877A. The Olimex boards are single sided so there is a tendency for pads to fall off after extensive modifications but they are excellent value for money for quick solutions to one-off problems.
    A small Outline SOIC8 pack is on a sub protytype board.
    I started out with the solderless breadboards. They are great while they are new and for prototyping small ideas. They get dust and other crap in the holes giving poor analog connections for 16 bit work. They are also relatively noisy with highish capacitance between pins. They rapidly reach a level of complexity where each new wire disturbs an existing wire and it gets very frustrating working out where any problems are. Full marks for skimask/mister e/whoever that just posted that monster solderless breadboard.
    With prototype PCB services now so affordable, I have made myself three general purpose boards for PIC 40 pin packs. I use EAGLE (paid 100 x 160 mm version) and get these made in Malaysia at CustomPCB for about $10 each in plate through double sided. These have headers for switch inputs, LCD outputs, SOIC 8, SOIC 16 and a reasonable sized prototyping area.
    HTH
    Brian
  1. Replies: 8
    Last Post: - 7th December 2006, 15:42
  2. PIC16F62x 18 pin SMT breakout PCB
    By jdgrotte in forum Adverts
    Last Post: - 1st January 2004, 08:59
