HPWM and timer 1 on pic16f77
Results 1 to 3 of 3
    Aug 2007
    Default HPWM and timer 1 on pic16f77
    im using a pic16f77 and am using the ccp in pwm to generate a 1khz square wave by the following
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    HPWM 1,127,1000
    this works fine until the main program starts (which uses the timer1 module for a counter) when the frequency changes to around 8Khz and i have no idea. Is there some port i need to set to keep it in hpwm mode or am is there something else going on
    thanks
    Probably you did something bad somewhere, this PIC use TIMER 2 for HPWM.
    Post your whole code here.. unless we can't help.
    Aug 2007
    Smile
    seem to have sorted it. appears something to do with PIR and PIE registers. commented it out and works as before but without the frequency changing
  1. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  2. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 22:01
  3. Dead PICs
    Last Post: - 15th August 2007, 14:12
  4. using darrel taylor's instant interrupts
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 05:07
  5. HPWM the old fashioned way
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2004, 20:09
