This is my first PIC Project and have enjoyed it so far but having trouble moving forward at the minute.
Details:
The PIC is been used for a prototype alarm system for toy car and hoping to then interface with PC to give a nice GUI and display which sensor was triggered.
list p=16f818 ; list directive to define processor
#include ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG H'3F10'
;***** VARIABLE DEFINITIONS
OPTION_R EQU 81H ;Option Register
ZEROBIT EQU 2 ;means ZEROBIT is bit 2.
COUNT EQU 20H ;COUNT a register to count events.
COUNTA EQU 21H
ORG 0x000 ; processor reset vector
goto main ; go to beginning of program
; SUBROUTINE SECTION.
DELAY MOVLW 0xFF ;load Decimal FF in W register
MOVWF COUNT ;load Count with contents of W register
LOADCA MOVLW 0xFF ;load Decimal FF in W register
MOVWF COUNTA ;load CountA with contents of W register
DEC DECFSZ COUNTA,F;decrement counterA and skip next line if Z=0
GOTO DEC ;if countA not 0 than go to DEC
DECFSZ COUNT,F ;decrement counter1 and skip next line if Z=0
GOTO LOADCA ;if count1 not 0 than go to LOADC2
RETURN ;else jump out of subroutine
;FLASH LEDS
LED BSF PORTA,0 ;Turn on A0
BSF PORTA,1 ;Turn on A1
BSF PORTA,2 ;Turn on A2
BSF PORTA,3 ;Turn on A3
CALL DELAY
BCF PORTA,0 ;Turn off A0
BCF PORTA,1 ;Turn off A1
BCF PORTA,2 ;Turn off A2
BCF PORTA,3 ;Turn off A3
;FLASHING LEDS
LEDs BSF PORTA,0 ;Turn on A0
CALL DELAY
CALL DELAY
GOTO LEDs
; CONFIGURATION SECTION.
main BSF STATUS,5 ;change to bank1
MOVLW B'11110000' ;Bits for mixed I/Os on portA
MOVWF TRISA
MOVLW B'00111011' ;Bits for mixed I/Os on portB
MOVWF TRISB
MOVLW B'00000000'
MOVWF OSCCON ;oscillator 31.25kHz
MOVLW B'00000111' ;prescaler is /256
MOVWF OPTION_R ;TIMER is 1/32 secs
BCF STATUS,5 ;return to bank0
BSF SSPCON,5 ;Set bit 5 to high to enable RB1, RB2 as serial I/O ports
CLRF PORTB ;clear portB register
CLRF PORTA ;clear portA register
CLRF COUNT ;clear count register
CLRF COUNTA ;clear countA register
;Program starts now.
ARM BTFSC PORTA,4 ;INPUT FOR TRANSMITTER
GOTO ALED
GOTO ARM
ALED CALL LED ;CALL LED SUBROUTINE
GOTO POLLING
POLLING BTFSS PORTB,0 ;CHECK ULTRASOUND
GOTO ALARM
BTFSS PORTB,1 ;CHECK DOOR 1
GOTO ALARM
BTFSS PORTB,5 ;CHECK DOOR 2
GOTO ALARM
BTFSS PORTB,4 ;CHECK TILT SWITCH
GOTO ALARM
GOTO POLLING
ALARM BSF PORTB,6 ;TURN ON ALARM
CALL LEDs ;FLASH LEDs
BTFSC PORTA,4 ;WAIT FOR PORT TO BE LOW
GOTO ALARM
CLRF PORTA
;BCF PORTA,6 ;TURN OFF ALARM
;BCF PORTA,0 ;Turn off A0
;BCF PORTA,1 ;Turn off A1
;BCF PORTA,2 ;Turn off A2
;BCF PORTA,3 ;Turn off A3
GOTO ARM
; initialize eeprom locations
ORG 0x2100
DE 0x00, 0x01, 0x02, 0x03
END ; directive 'end of program'
So any help would be great also I'm using MPLAB V8 and a PICstart programmer to burn the PIC.
Thanks again
