Need ISP circuit
Results 1 to 7 of 7
    However, I have had excellent results with parallel port based programmer(s).
    How many parallel ports does the average PC have these days?
    Especially a PC owned by an up-and-coming youngster who's aim is to build the next greatest thing?
    So much so that I have never (till now, at least) been tempted to switch over to a USB programmer.
    Have you tried the PICKIT2? Especially with its latest software/firmware update which includes that handy little logic analyzer?
    I can almost guarantee 100% you'll like it far, FAR better than you think...
    Everybody have their own opinions. I'm not going to contradict ANYBODY here.
    Here's my 2 cents point of view.
    You always got for what you pay for. This has to be true in many cases. See, JDM or else "freebies" using WinpicProg, PONY, IC-PROG or whatever else Free one. Damn all free software, single developer or so. 1 new PIC almost each days/week. They can't follow the evolution huh? Well unless it's developer is retired and do it all the time. I heard that few people MUST switch between xyz software to program a specific PIC... waste of time to me. But agreed... the software is free.. and the programmer can be built with scavenged PC, boards or whatsoever else. Cost 0$ or so.
    Yes i heard some free parallel programmer work better than serial... reason is obvious... timing. JDM or else low-count part one might never ever work on XP... VISTA? Fine if you still have an old Win98, it ought to work.
    What happen if you have issue? How much time you took to build your programmer? How much time you wasted to answer question why it doesn't work? How much time you waste because you wanted a solution NOW? I will assume at very **** least 3-4 hours or so. Give yourself 10$/hour (which is really ridiculous anyways) this mean you lost 30-40$ for something that doesn't really work.
    For almost the same price, you buy a PICKIT 2 (or JuneBug) which is made by the one who BUILD PIC... so at least they know how to program them, they're not alone to develop the according firmware/software, and they will still be there tomorrow, next week, next year to support it + they will answer to ANY question 7/7 24/24.. how about your freebies?
    As if it wasn't enough for $40 bucks, they'd dare to add EEPROMS, KeeLoq, ICD, Logic Analyser (generator... kind of), Rs232 terminal (without any need for a Max232), AND MORE it's also programmer-to-go (program your PIC without any PC).
    I'd spend thousandS dollars on PIC programmer/development board 'till now. YES i NEVER used ANY freebies. My first was PICSTART (with PUM), then BK Precision 844a, then ICD-2 (used 3-4 times), then PICKIT 2, then Mikroe Dev boards (EasyPIC 4, EasyDsPIC 4) and then few others i don't remind their name for Blackfin. NONE of those had let me down 'till now... WHY because you got for what you pay for!
    On the other side... PICKIT 2 is so cheap... BUT it support a wide range of their products.. from EEPROMs, Keeloq, PIC10f to PIC32... kinda attractive... way to go when you want to promote your products!
    Apr 2008
    Default reply up
    thanks for your advise
    Mar 2006
    Talking
    Sir:
    I'd like to know if you have had any experience or ever come across with ARM architecture how does it compare to blackfin?
  1. Circuit Design Question
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 09:18
  2. Short circuit portection circuit ?
    By iugmoh in forum Schematics
    Last Post: - 21st December 2008, 22:33
  3. Replies: 1
    Last Post: - 11th December 2007, 00:57
  4. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  5. Replies: 3
    Last Post: - 29th October 2006, 10:16
