Pic Basic TouchScreen? How?
Results 1 to 19 of 19
    Mar 2008
    Lightbulb Pic Basic TouchScreen? How?
    Hey.
    I want to ask if some of you guys know anything to control a TouchScreen without using a ADC Chip, just the PIC A/D Inputs (I'm using PIC2550)
    Hope you can help me out with my 4 wire TouchScreen
    Best Regards
    Thomas Jespersen
    Yes........
    more details=more chance to have help. resistive, capacitive, UFO driven or what? Any model/brand ?
    I got some from CircuitEd.
    Mar 2008
    I don't want to buy it form CircuitED as the freight cost is so expensive as i live in Europe
    But if it was cheaper (the freight) then i would like to buy the RGB GLCD With TouchScreen!
    But i've found this instead, and it's from a shop in Europe, so it's perfect
    This is the datasheet for the TouchScreen: http://www.mikroe.com/pdf/touch_scre...cification.pdf
    And if you look at nearly the bottom of this page, you see
    Graphic LCD 128x64 with TouchScreen | $24.00USD
    Thank You
    Seems to be the same i have.. It's a Resistive one, the GLCD controller is this Grandpa KS0108.
    The following could give you few hints...
    http://www.hitachi-displays-eu.com/d...Technology.pdf
    http://www.eetindia.co.in/ARTICLES/2...URCES=DOWNLOAD
    http://www.monolitic.com/esp/Notas/t..._resistivo.pdf
    http://www.sfcompiler.co.uk/wiki/pmw...er.TouchScreen
    Talking I want some precision, but with POT or RCTime commands ...
    Hi, Thomas
    you,ve the "official" scheme on the MkE Databook for EasyPic boards...
    Thumbs down
    Yes but you really don't need all of those extra transistors, resistors, capacitors stuff...
    If you carefully read and understand the documents above, you'll see how easy it is.
    I think SteveB already post a code snip for that last year or so. I Haven't compared mine with his one yet.
    One more
    http://electronix.ru/forum/index.php...=post&id=18229
    Another one? Why not
    http://www.circuitcellar.com/avr2004...86abstract.pdf
    Talking
    Hi, Steve ...
    When it works fine ... I consider the solution as GOOD !!!
    No extra brain twist required ... LOL !
    May be ... just have a better-than-genuine data acquisition ( just move stylus quickly, and you'll understand what I mean ... hé,hé ! )
    May be ... also some better linearity enhancements ???
    Talking
    yeah but where's the fun using copy/paste ?
    Talking
    No need to re-build the world ... just enhance it gives enough work for everyone ... !!!
    Mar 2008
    The last one is the only with a code snippet, but it isn't in PBP!
    but i will try and read all the documents, but i am not good at ADC in PBP ;-)
    Mar 2008
    Default TouchScreen Controller
    What does this do, and would it be easier to use a touchscreen if i buy this:
    http://www.mikroe.com/en/tools/touchcont/
    It's exactly the same draver as Alain's EasyPIC 5 board.
    It may help.. but i stand to tell you don't need it.
    Mar 2008
    But if i don't buy that, i would need to make a circuit who are correcting the Touch Values into the 0-5V range, right?
    But do you have a PBP Example, because you sounds like you know alot, as i don't!
    Begin with the following...
    http://www.picbasic.co.uk/forum/show...44&postcount=7
    Then send your results to your PC or any LCD, then try to understand what happen.
    Mar 2008
    Then what if i use that touchscreen controller, then i shouldn't High any ports, should i?
    Yes, you'll still need to play with high/low, ADC conversion etc etc... hence why i told you that you don't need it.. even your new compiler haven't it built-in
    Mar 2008
    New Compiler?
    But could you please look at this datasheet, and tell me what ports that should go to what (X+, X-, Y-, X- as there is in the PBP code, but this have some others)
    http://www.mikroe.com/pdf/touchpanel...matic_v102.pdf
    North Norfolk UK
    Quote Originally Posted by mindthomas View Post
    See your other thread of endless how-to posts...
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 06:09
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 01:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 22:10
