Need Help with USB using PIC18F2455
Results 1 to 18 of 18
    I have the same problem I can't use your USBDEMO since I don't have pic18f4450 but I have pic18LF445, so in microcode when I switch to this model I have compile error
    ERROR: Macro USBINIT? not found in macro file.
    ERROR: Macro USBSERVICE? not found in macro file.
    ERROR: Macro USBIN?CBBL not found in macro file.
    ERROR: Macro USBOUT?CBBL not found in macro file.
    You must mean 18F4455, so just use the files in attachment. Tested and work as expected here. i just forgot to change the device name in the top comments...
    @Darrel... link to this one too
    There is an error:
    ERROR Line 78: Syntax error. (USBDemo_4455.pbp)
    this line : UCFG = %00010100 ' enable internal USB pull-up, Full speed USB
    but when I comment it , it's compiled without any errors
    HA! so that mean you may use V2.47 of the compiler right?
    I thought i would remove the
    UCFG    var byte EXT
    line because some had 'Redefinition of VAR' problem with V2.50.. anyways, it should work, unless you know what else to add
    I'm a bit mixed-up... your thread name is Need Help with USB using PIC18F2455
    yes I'm use PBP247 , oky I compile and load the hex file but the same problem
    I have some questions:
    1)Can I use any type of the 470nF capacitor because I'm not use ceramic I use mica
    2) Does I need special way to load my hex file to pic or any programmer, I use superpro 280U programmer.
    You shouldn't have any problem with mica cap.
    In your device programmer software you may have an option to program the config fuses setting or not. I don't have this specific programmer and seems their software refuse to install on my machine... so i can't really help you on that.
    Have you already program other PICs with this one?
    I don't have any problems with this programmer , I used it many times and it has a high performance , and you can set config fuses using programmer software or from PICBASIC , and here we add them using picbasic so it's updated automatically in programmer software
    I will attach the configuration fuses photos
    ' Pic Configuration
    asm
    __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ; ; ; USB clock source comes from the 96 MHz PLL divided by 2
    ; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    ; No prescale (4 MHz oscillator input drives PLL directly)
    __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ; ; ; Oscillator Switchover mode disabled
    ; ; Fail-Safe Clock Monitor disabled
    ; XT oscillator, PLL enabled, XT used by USB
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 03:46
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
