Need Help with USB using PIC18F2455
Results 1 to 18 of 18
    Default Need Help with USB using PIC18F2455
    I use EasyHID to generate both PICBASIC code and visual basic code, I connected the cicuit as shown in various posts and schematics, but evey time I plug the usb cable in our laptop or my PC I have a problem "USB Device Not recognized" , I sure that I'm connected the circuit well with 470nF capacitor but the same problem , I think there are a driver I must install or something else.
    I attached my photos for clearing
    Most problem comes with the ConfigFuse setting, then the code. Is it me.. or i don't any of those here?
    You'll also need to tell us which crystal/resonator speed you have.
    I saw you looked at USBDemo... you didn't find anything to use in?
    Oky here is my code which I use 4MHZ crystal:
    ' Pic Configuration
    asm
    __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ; ; ; USB clock source comes from the 96 MHz PLL divided by 2
    ; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    ; No prescale (4 MHz oscillator input drives PLL directly)
    __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ; ; ; Oscillator Switchover mode disabled
    ; ; Fail-Safe Clock Monitor disabled
    ; XT oscillator, PLL enabled, XT used by USB
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    DEFINE OSC 48
    ;DEFINE LOADER_USED 1
    symbol led=portb.7
    output led
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    low led
    usbinit ' initialise USB...
    ProgramStart:
    gosub DoUSBIn
    toggle led
    gosub DoUSBOut
    toggle led
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    this section will cause you a problem
    gosub DoUSBIn
    toggle led
    gosub DoUSBOut
    toggle led
    goto ProgramStart
    Why? because of this section
    The easy way will be to use Darrel's instant interrupts. Here's the famous POST 148
    http://www.picbasic.co.uk/forum/show...&postcount=148
    Iam from begining not include delay of 100ms but I added them to give indication for led about where the code stuck and find that It's stuck in DousbIn subroutine. now I'm removed the delay time and the same problem , I don't know where is the problem ????????????
    DoUSBIn:
            USBIn 1, USBBuffer, USBBufferCount, TimeOut ' No data?, Getout of here
    TimeOut:
    Do you still have the USB connection error?
    Maybe better to begin with USBDemo and work around with? There's a load of information in that thread (ok ~180 post to read but)
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 03:46
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
