How to isolate 10 bits from word variable?
Results 1 to 7 of 7
    Question How to isolate 10 bits from word variable?
    Hello All: Could someone explain how to isolate just the 10 Most significant bits from a word variable?.
    Example:%1111111100000000 (16 bit word read from device)
    I would like to get this:
    My10Bits=%1111111100 (10 bits actual data)
    I am using PicBasic-Pro 2.50
    Thanks in advance
    Bob C.
    Oct 2003
    holland
    A word consits of a high byte and a low byte. (see manual)
    There is also a shift (right) possibility in PBP. (>>)
    Only you have to copy the lsb of the high byte to the msb of the low byte after every shift.
    Feb 2003
    Salt Lake City, Utah USA
    Also try, as suggested by Mat
    My16Bits = %1111111100000000
    My10Bits=My16Bits >> 6 ; lose the lower 6 bits (same as divide by 64)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Default Thanks Matt
    Thank you for your response:
    The problem I'm having is joining the entire Highbyte of the Word variable with the 2 MSB's of the Lowbyte to form my 10 Bits.
    I know I need to concatenate the bits together,but I am getting a bit frustrated by this...If you or anyone else can show me the coding syntax for this operation I would appreciate it.
    The concatenated bits will be placed in a word variable .
    Down and out
    Bob C.
    Unhappy Rtfm !!!
    Pfouuuuuh !!!
    A is a Byte - Lower Part of THE 16bits value VAL
    B is a Byte - Higher Part ....
    VAL.Lowbyte = A
    VAL.Highbyte = B
    That'a All ...
    and VAL >> 6 is What you look for.
    Final point.
    Smile Thanks Everyone!
    I now understand the process!!!....ACE-I honestly RTFM but I guess I just was not understanding.
    In your honor Ace I have declared RTFM as a Word variable and will use it my program
    Again,thanks for helping me out gentleman!!
    Bob C
    some may have learn from this RTFM expression
    http://www.rtfm.com/
    Some also did come cofee cup
    Last Post: - 14th June 2016, 08:55
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    Last Post: - 31st March 2006, 16:23
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
