Synchronisation between two DSpic30F2010
Results 1 to 3 of 3
    khalid4145's Avatar
    khalid4145 Guest
    Default Synchronisation between two DSpic30F2010
    I have to use 10 PWM in my circuit. i am using dspic30F2010 and i was succeeded to control 6 channels? but i need 4 more. the problem that one dspic30F2010 gives you only 6 PWM channels. one told me that i could do a synchornisation between the two chips of dspic30F2010 but actually i dont know how to do that. Any body can help??
    North Norfolk UK
    Quote Originally Posted by khalid4145 View Post
    i am using dspic30F2010.......... Any body can help??
    Hi Khalid
    Maybe not sure about the support for the dspic30F2010
    which compiler are use using for this?
    rgds
    Hi Khalid,
    The best place to go would be MicroChip forum.
    http://forum.microchip.com/
    Here, our compiler don't support them 'till now
    Depending how accurate/fast you want your PWM signal. You could still roll your own using an Timer interrupt, or look for a bigger DsPIC with more PWM channel.... the biggest i know have 8 PWM channels in though
    Why you need them in-synch?
  1. dsPIC30F2010
    By dome.viola in forum mel PIC BASIC
    Last Post: - 29th April 2008, 17:47
  2. dspic30f2010
    By andrewwaack in forum General
    Last Post: - 26th February 2008, 12:22
  3. dsPIC30F2010
    By puma in forum mel PIC BASIC Pro
    Last Post: - 1st August 2004, 00:27
