Need help isolating 1/2 portb
Results 1 to 5 of 5
    Mar 2004
    Default Need help isolating 1/2 portb
    I am using a pic 16f628 Portb.0 - portb3 as outputs and portb4 - portb7 as inputs. I have set the trisb correctly but cant figure out how to read the inputs only. Can someone give me some ideas
    You have several options depending on what you application requires.
    X VAR BYTE
    OPTION_REG.7 = 0 ' Pull-ups on for inputs
    TRISB = %11110000
    ' Shift upper 4-bits into lower 4-bit positions.
    X = PORTB >> 4 ' X returns 0 to 15
    ' Mask lower nibble from result.
    X = PORTB & %11110000 ' X returns upper 4-bits, 0's for lower.
    ' Test individual bits one by one.
    IF PORTB.7 = ? THEN
    IF PORTB.6 = ? THEN, etc,,,
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2004
    Thanks Bruce
    I worked out another way to do it also, but no sure if it is correct but seems to work ok for me
    b0=portb
    b1=b0 & %11110000
    b2=b1/16
    also can you please explain
    I am currently using external resistors for pull-ups and I would like to get rid of them if I can
    b0=portb
    b1=b0 & %11110000
    b2=b1/16
    That will definitely work but, b0 = PORTB >> 4 gives you the same result, uses less program code space, and saves you 2 RAM variables.
    On most PIC's (check your datasheet) bit #7 of the OPTION_REG register turns ON or OFF PORTB internal pull-ups. OPTION_REG.7 = 0 turns them ON. OPTION_REG.7 = 1 turns them OFF.
    PORTB pins set to inputs will have the weak internal pull-ups. PORTB pins configured as outputs are not affected.
    -Bruce
    tech at rentron.com
    Mar 2004
    Many thanks Bruce
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 17:23
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
