PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
Results 1 to 6 of 6
    SWITZERLAND (french speaking)
    Default PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Hello,
    I'm building a IR remote control based on Bruce's information (http://www.rentron.com/Infrared_Communication.htm).
    The IR link (hardware) works fine but I can't get the communication between both PICs working since I'm not familiar with the SERIN2 command.
    To go on step-by-step, I don't use the IR system for the moment and "wired" both PICs together (via a 1k2 resistor).
    The "emitter" PIC sends continuously this "ABCD1234efgh5678" string and this works fine. The (shortened) code in the "emitter" PIC is:
    MAIN:
        SEROUT2 D_Out, 49548, ["ABCD1234efgh5678", 13]
        GOTO MAIN
    The "receiver" PIC is setup to receive () the string and send it out to a Serial Terminal (currently for testing purpose).
    Based on the PBP "SER2MOD" example, the "receiver" code looks like this and should make the program wait for the "A" character to be received and read the seven next characters:
    ' Fuses  PIC12F675
    @ DEVICE XT_OSC ;Xtal 4MHz
    @ DEVICE WDT_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE MCLR_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PROTECT_OFF
    @ DEVICE CPD_OFF
    CMCON      = %00000111 'Comparator is OFF
    ANSEL      = %00000000 'Disable analog inputs
    OPTION_REG = %10000000 'GPIO Pull-Ups disabled
    INTCON     = %00000000 'All Interrupts disabled
    GPIO       = %00000000 'Ports Levels
    TRISIO     = %00001000 'Ports Directions
    D_Out  VAR GPIO.2 'Serial Data Out
    D_In   VAR GPIO.3 'Serial Data In
    D_Data VAR byte[8]'Serial Data
    MAIN:
        SERIN2 D_In, 49548, [WAIT("A"), STR D_Data\7]
        SEROUT2 D_Out, 49548,[STR D_Data\7, 13, 10]
        GOTO MAIN
    Problem: it seems I don't get anything into the receiver PIC or at least, this is what I feel since the Serial Terminal stays blank.
    NB: 49548 is the data mode: 2400bauds, Open, Inverted, No Parity.
    Roger
    Hi Roger,
    Do you have a Pull-Up resistor on the serial line?
    SEROUT2 mode 49548 is Open Collector output. It never drives the line high, so it requires a pull-up.
    From your description, it sounds like you just have a 1.2k in series.
    Alternatively, you can use mode 16780 which will drive it high.
    Sounds right... not sure how and why SERIN2 deal with it... how on earth an input could be an open-collector type NO i haven't open the LIB(s)
    As far as SERIN2 is concerned, it doesn't matter.
    49548 and 16780 are the same thing.
    But it will make a difference with the SEROUT2.
    49548 - open collector output.
    16780 - Driven output.
    <br.
    ...Do you have a Pull-Up resistor on the serial line?
    Yes, a 10k. The 1k2 resistor is connected between both PICs.
    I'll have a try with a driven output.
    Roger
    Default another transmission protocol
    Looking around the Internet for some additional information about IR transmission, I found out that i.e. SONY uses a Pulse Width Modulation protocol that looks simple to implement with PICs (http://www.sbprojects.com/knowledge/ir/sirc.htm).
    So instead of trying to establish a "serial" communication, I'll have a go with PULSOUT/PULSIN.
    Might be easier since the IR (hardware) layer is already working well.
    Roger
  1. 2 PIC, serial communication
    By lightgreen in forum Serial
    Last Post: - 21st November 2009, 16:20
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. Replies: 5
    Last Post: - 20th March 2006, 02:34
  4. Pic To Pic Serial Communication?
    Last Post: - 5th February 2005, 01:59
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
