Originally Posted by
PICante
Hello again!
I found a few differences in “P16F88.inc” compared to the datasheet, one example is “BODEN” vs “BOREN” and I am not sure what to make of this. Here’s how the code looks now:
@ __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
@ __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
DEFINE OSC 8
OSCCON = %01110000 ' INTRC = 8MHz
TRISB = 0
'---------------- move LCD to portB---------
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 5
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 4
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
LCDOUT $FE, 1,"TEST"
Thanks!
Do it the way it is in the 16F88.inc file
The configs liisted require you to use MPASM as the assembler.
