Moving the LCD
Results 1 to 11 of 11
Thread: Moving the LCD
    Dec 2007
    Question
    Hello again!
    I made a small change to the config bits (_INTRC_IO ) and get “Owerwriting previous address contents (2007)” from MCS+. The exact same message pops up with the config bits unchanged. I found a few differences in “P16F88.inc” compared to the datasheet, one example is “BODEN” vs “BOREN” and I am not sure what to make of this. Here’s how the code looks now:
    @ __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
    @ __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
    DEFINE OSC 8
    OSCCON = %01110000 ' INTRC = 8MHz
    TRISB = 0
    '---------------- move LCD to portB---------
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    LCDOUT $FE, 1,"TEST"
    Thanks!
    Quote Originally Posted by PICante View Post
    Hello again!
    DEFINE OSC 8
    TRISB = 0
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Thanks!
    Do it the way it is in the 16F88.inc file
    The configs liisted require you to use MPASM as the assembler.
    Joe, he use MPASM already, hence why he got Argument out of range (not a valid config register address)”
    Picante, read this one...
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    Dec 2007
    Hi Joe.
    I am using MPASM!
    Thanks.
    Hi Joe.
    I am using MPASM!
    Thanks.
    OK good. Seems I always get in trouble when using the Wife's computer . . .
    OK so all you have to do is open the 16f88.inc file in PBP and insert a semicolon before the config statement like so:
    ;__config _CONFIG1, _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF and it will compile.
    Dec 2007
    Talking
    Allright, I edited the PBP inc file by changing the oscillator to internal this way I don’t need the config fuses in the code. Right or wrong, it’s convenient when testing out things and I am on to the next step in the code, the ADCIN. We’ll see how that will develop, might need more help in the near future.
    Thanks for now Guys!
    You’re the best!
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
