I use positive presensitized boards for my prototyping. No problems with SOICs.
Print the art work on a transparency.
Clap the transparency to the board with a piece of glass.
(Now for the strange part, I do not have a light box. I live in SW Arizona.)
Set the board, artwork, glass clamp up out side for about 20 minutes. Double sided, flip in 15. You can see when it is finished.
Chemicals. I then use a weak solution of KOH to remove the reacted coating. Rinse with water and etch with ferric chloride.
Not a big deal.
Not sure about Eagle, if it will make a gerber file it should be fine.
That is my two cents.![]()
