Analog to digital phone line
Results 1 to 5 of 5
    Apr 2008
    Default Analog to digital phone line
    Hi
    AT the moment if my house alarm goes off, it calls my mobile using the standard analog line.I was going to switch to NTL broadband, but it seems they do not know how to connect my alarm to their line.My alarm uses the standard telephone line to call mobiles.Any way I could keep this functionality?
    tks
    Does it allow to keep your old phone or you need to buy new ones?
    If so, here i have Videotron service, and they just do a simple loop with existing telephone wires. So their Modem output goes directly to the Alarm System dialer input, and then dialer output goes to regular telephone wires.
    I've both BT (analogue) and NTL (digital) lines in my home. The phones are interchangeable. There is NO difference in the devices you can plug into the respective sockets. I also have Broadband on both... and can say that Digital is by far, way superior, not only in performance but also in reliability in adverse conditions (your Digital DSL modem is NOT the same as your analogue ADSL modem).
    There is only ONE exception. Those are the 100% 24/7 monitored alarms (ie they are permanently connected to a remote monitoring station) and because they are permanently connected, the remote station detects when someone has cut the phone lines to your house. You would need to speak to your monitoring company provider about the change.
    Jun 2007
    england
    Default Hope this helps
    if you measure with a volt meter the lines you will notice that bt runs at 50 volts on hook and ntl works at 40 volts on hook. this voltage sometimes stops automatic dialers from connecting and the resistor value connected to the opto isolator that makes the line go off hook will require changing.
    Apr 2008
    I was told that If the alarm is connected to the analog line, and I connect it to the digital ( NTL ) it wouldn't work, as it needs analog, I not an expert, so I believed it (: So you reckon that shouldn't be any problems if I connect the alarm ( astec 63dv ) to ntl line? I mean it should be able to call mobiles??
    thanks
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  4. analog and digital
    Last Post: - 10th June 2008, 03:40
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
