Bcd Fomat Help
Results 1 to 17 of 17
Thread: Bcd Fomat Help
Threaded View
  1. #8
    Convert BCD to decimal... assume variable RTCSeconds holds the seconds in BCD format...
    First let's deal with the TENS value (Bits 4,5 and 6)...
    DecimalSeconds=RTCSeconds & $70
    DecimalSeconds=DecimalSeconds>>4
    DecimalSeconds=DecimalSeconds*10
    And finally add-in the UNITS value...
    DecimalSeconds=DecimalSeconds+(RTCSeconds & $0F)
    To convert Decimal back to BCD, reverse the Process...
    RTCSeconds=DecimalSeconds DIG 1
    RTCSeconds=RTCSeconds<<4
    RTCSeconds=RTCSeconds+(DecimalSeconds DIG 0)
    Incorporate the above into a General Purpose Subroutine and use the same single routine to convert Seconds, Minutes, Hours etc etc.
    Melanie
    Thanks a lot. I was breaking my head from last few days to learn this. You have really explained it very nicely.
    BUT
    I am facing slight problem in my simulation (I am using proteus).
    My code looks like this when program starts for the first time:
    Rtcget		var byte[8]
    Rtcsec		var Rtcget[0]
    Rtcmin		var Rtcget[1]
    Rtchr		var Rtcget[2]
    Rtcday		var Rtcget[3]
    read 30,check
    if check=0 then
    	pause 50
    	I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$12,$01,$00,$00,$00,$90]
    	pause 50
    	write 30,1
    	I2CREAD SDA,SCL,$D1,$00,[STR Rtcget\8]
    		pause 50
    		sec=Rtcsec & $70
    		sec = sec>>4
    		sec=sec*10
    		sec=sec +(Rtcsec & $0F)
    		minu=Rtcmin & $70
    		minu = minu>>4
    		minu=minu*10
    		minu=minu +(Rtcmin & $0F)
    		hrs=Rtchr & $30
    		hrs=hrs>>4
    		hrs=hrs*10
    		hrs=hrs+(Rtchr & $0F)
    		if Rtcday=$01 then days=1
    		if Rtcday=$02 then days=2
    		if Rtcday=$03 then days=3
    		if Rtcday=$04 then days=4
    		if Rtcday=$05 then days=5
    		if Rtcday=$06 then days=6
    		if Rtcday=$07 then days=7
    & when user changes the time it looks like this
    Rtcmin=minu DIG 1
    					Rtcmin=Rtcmin<<4
    					Rtcmin=Rtcmin+(minu DIG 0)
    					Rtchr=hrs DIG 1
    					Rtchr=Rtchr<<4
    					Rtchr=Rtchr+(hrs DIG 0)
    					if days=1 then Rtcday=$01
    					if days=2 then Rtcday=$02
    					if days=3 then Rtcday=$03
    					if days=4 then Rtcday=$04
    					if days=5 then Rtcday=$05
    					if days=6 then Rtcday=$06
    					if days=7 then Rtcday=$07
    				I2CWRITE SDA,SCL,$D0,$00,[$00,Rtcmin,Rtchr,Rtcday,$00,$00,$00,$90]
    				PAUSE 20
    The problem is that during simulation, the frequency of the pulse changes once I set the time (coming from DS1307 - I want 1Hz)
    Please point out the problem in my code if any, or is it the simulation software which is not correct (Proteus 6.9)
    ___________________
    WHY things get boring when they work just fine?
  1. DS1302 16F628 Woes
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 14:15
  2. BCD problem
    Last Post: - 14th September 2008, 16:36
  3. Rotary BCD
    Last Post: - 15th October 2007, 03:04
  4. Real time clock... what a headache!
    By Eng4444 in forum mel PIC BASIC
    Last Post: - 8th June 2006, 21:56
  5. Leading 0's or BCD
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 01:06
