I2C Read and Write
Results 1 to 15 of 15
    Apr 2008
    Default I2C Read and Write
    Hi I was wondering if anyone could give me a clue as to what's going wrong here, it's driving me nuts? Signals look ok as far as I can see, 4k7 pull ups fitted on both lines
    I've got a P18f252 interfaceing with a 24LC84 eeprom, it's in HS PLL mode, the eeprom is the only device on the bus...
    Any help would be appreciated.
    My code is sitting in a loop with the following code...
    'defines
    'DEFINE OSC 40 ' Operating frequency
    'DEFINE I2C_SLOW 1
    'I2C_CON CON %10100000 ' Memory I2c control byte
    'i2c_sda var PORTA.0 ' I2C serial data line
    'i2c_scl var PORTA.1 ' I2C serial clock line
    mem_off = 0;
    MyWordWr = MyWordWr+1
    i2cwrite i2c_sda, i2c_scl, I2C_CON, mem_off, [MyWordWr]
    i2cRead i2c_sda, i2c_scl, I2C_CON, mem_off, [MyWordRd]
    ram[F05_HI] = MyWordRd/256 'This register can be read over modbus
    ram[F05_LO] = MyWordRd
    ram[F10_HI] = MyWordWr/256 'This register can be read over modbus
    ram[F10_LO] = MyWordWr
    Mar 2008
    Texas, USA
    change this to a var, not con
    from the pbp manual:
    " Constants should not be used for the address as the size can vary dependent on the size of the constant. "
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Apr 2008
    Hi thanks for replying... though the 'I2C_CON CON %10100000 ' is my control byte, not the address which is 'mem_off' and declared as a word.
    I'll give it a shot though.
    Thanks again.
    Derek
    Apr 2008
    Defining the control byte as a var didn't help... so I need to keep looking (
    Also I've noticed that if I put a 10ms Pause between my write and read my serial coms stops responding, does the PAUSE command disable the interupts or something?
    Make sure you have disabled all multiplexed Analog modules on the pin you're using. (ADCs and/or comparators)
    Could be interesting to see your config fuses setting... and the whole code.
    Well, I did a search for a 24LC84 and could not find a data sheet anywhere. What size is this part? If it is bigger than 32 kbits, then it probably needs a word size value for mem_off. For your ram_lo data I think you should mask off the upper byte by and'ing MyWordWrite and MyWordRead with 0xFF. Or use the .lowbyte and .highbyte modifiers. In fact, I don't see size definitions for any of your variables. Is mem_off a byte or word variable? Is ram a byte or word array? What are F05 and F10 defined as?
    Tim Barr
    Quote Originally Posted by DerekMacom View Post
    Serial rate of 9600 baud is about 1 msec per character so a 10 msec pause could definately cause problems. The manual says this about HSERIN:
    "As the hardware serial port only has a 2 byte input buffer, it can easily overflow if characters are not read from it often enough."
    You might have to break up the pause into chunks and do a serial read in between. Maybe do 3-4 HSERIN or SERIN calls with a 2-3 msec timeout.
    Tim Barr
    Mar 2008
    Texas, USA
    Tim, it doesn't look like he's using the HSERIN. Ports RA.0 and RA.1 aren't the serial ports on this PIC.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 14:06
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
