Demux
Results 1 to 7 of 7
Thread: Demux
    xnihilo's Avatar
    xnihilo Guest
    Smile Demux
    Hi guys!
    I need to redirect voltage from the input to one of many outputs, in sequence, everytime I put a voltage pulse on the input pin.
    Imagine there are 16 outputs available, I connect a led to each output and I want that everytime I pulse the single input, it turns of the previous led and turns on the next led, like some sort of sequential switcher but I have merely one or two PIC pins availables to control the multiple output device.
    Does someone know if such thing exist? Maybe a Demultiplexer of some kind?
    You are looking for a shift register. Takes three pins to run 8 out puts, 4pins for 16 out puts if you use two.
    If I remember a part number HC595. That might be for in put. They have them for both.
    xnihilo's Avatar
    xnihilo Guest
    Unhappy
    This kind of thing. I know there are Demultiplexers (I have the datasheet) but I need a device where I have an input and a strobe line and multiple outputs. Everytime I use the strobe I switch to the next outpput :'(
    I don't have 4 outputs left on my PIC.
    Just a thought to make one.
    Find a PIC with enough I/Os. 1 input and 16? outputs.
    Code something like..
    If PIN_IN is high then
    count = count +1
    If count = 1 then high LED1
    If count = 2 then high LED2
    so on and so on...
    If count = 17 then count = 0
    Start over.
    Every time PIN_IN goes high the counter increases.
    xnihilo's Avatar
    xnihilo Guest
    count = count +1
    so on and so on...
    Start over.
    Sure, but i was thinking about a cheaper solution. Such pic costs over 3usd. a demux is about .60 usd. i can't beleive such step-up switch doesn't exist.
    Jan 2006
    Istanbul
    4017 is what you need.
    You can have as many as you want with cascading.
    A single pulse is good enough for all.
  1. Demux
    Last Post: - 13th April 2008, 18:15
