Protect eeprom during programming
Results 1 to 8 of 8
    Default Protect eeprom during programming
    Good evening all,
    I'm using several 16F886 in a RS485 network. Every PIC will keep indivual information in his data eeprom (like device ID etc). This information must be kept, also when a firmware upgrade is performed.
    When programming the PIC with the new firmware, the Eeprom of the PIC is also erased. I tried to set individual fuses (CPD bit) however with no results, the eeprom is always erased.
    Has anyone an idea how this can be solved?
    Many thanks for your help
    Wilbert
    PS: i'm using xwisp2w programming software and the wisp programmer
    North Norfolk UK
    you could ask Wouter van Ooijen himself. to introduce more commands than bulk erase.
    you could consider purchasing a programmer that will allow you do you what you want
    Curious... Do you use PIC Basic?
    regards
    Duncan
    Thanks for your reply !
    I'm using Pic Basic Pro 2.5
    I've already contacted Wouter a few days ago, it's not included for the moment and it could take months before he has the time to do it.
    Which programmer should i use that allows this feature?
    Wilbert
    North Norfolk UK
    Hi Wilbert
    Welcome to the forum ,
    there are several progammers, may I ask which IDE you use Mplab,Microcode studio etc it may help a little.
    I am shooting away right now, but am sure others can help out with this one
    regards
    Duncan
    Thanks for welcoming me
    I'm using Microcode Studio in combination with MPLAB. I would like to find a good in circuit programmer.
    Many thanks for your help, this is really appreciated !
    Wilbert
    In MPLAB click programmer in the tool bar. Then click settings. There you will find the place to not erase the EEPROM.
    ISCP = PICKIT2 from MICROCHIP.
    Also has a way not to erase the EEPROM during programming.
    Thanks Dave !
    I just looked online and the Pickit2 seems to me a good solution. I will buy one.
    Best regards
    Wilbert
    It is a good solution. It's also a InCircuitDebugger, EEPROM programmer, and the standalone PC software also give you a free SerialCommunication terminal. No need Max232. Can be integrated in MicroCodeStudio programmer list as well.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
