Advice on Input circuitry for 0-10v or Pot
Results 1 to 19 of 19
    The pot is there for calibration purpose only. inject 10V at the input, then adjust the pot to reach 5v... a bit useless in most case
    malc-c's Avatar
    malc-c Guest
    So in essance its a straight divider, 5V (+ or - 0.25 ish of a volt).
    So how would you then take the 5v output and use this to give a voltage range the ADC can use to intern generate the PWM to dim the LED. I assum that any pot between 5v and gnd will thus be in parallel with the 9.1K, hence your comments regardig Ohms Law
    EDIT:
    Or have I missed something, in that the 0-10v stated in the original post is already a varible voltage between zero and 10v, rather than a fixed 10v supply ? If so then I can see your logic
    i'm not sue if i follow you malc ... not sure you follow us too no pun intended
    You take the output and plug it directly to the PIC... straight, not much. Sugarless, fat-free, not much, zip, zero,nada. Want to use it to dim a LED? easy...
    ADCIN 0, ByteVar
    HPWM 1,ByteVar,Freq
    If i haven't missed anything in the OP request, he have an external source which provide voltage between 0-10V... and want to monitor it (for xyz reason) with a PIC, hence why the voltage divider.
    malc-c's Avatar
    malc-c Guest
    That's the part I missed - I was assuming it was a fixed 10v supply
    I don't see why any PIC should be used here anyway
  1. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:23
  2. 0 - 10V input on PIC 16F876
    By slayerizer in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 07:25
  3. Digital Pot Advice
    Last Post: - 22nd October 2007, 20:38
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Replies: 4
    Last Post: - 24th January 2007, 22:20
