Advice on Input circuitry for 0-10v or Pot
Results 1 to 19 of 19
    Feb 2003
    Sydney, Australia
    Default Advice on Input circuitry for 0-10v or Pot
    SO I was in the pub with a friend the other night and he was telling me about the led dimmers he had seen at work that took a 0-10v signal OR a 10K pot to set the brightness.
    Thats dead easy I said - I could do that with an 8 pin pic with build in PWM and a MOSFET.
    So he says 'OK then. Build me one for the kitchen. $20 says you can't..'
    So I can get a voltage input to drive it no issue by feeding it through a non-inverting LM358 with a gain of x0.5 to get a 0-5v output into the AtoD on a 12F683.
    What I can't work out is how to get a 10K pot and a 0-10v input (obviously only one is used at a time) I was thinking a pot between Gnd and the input that could use a soft 'pull up' that forms the top end giving a variable voltage that could drive the op-amp.
    Analog is not really my thing - I am a definately digital guy and have tried googling under various things, but cannot find out how a front end like those functions. Might have to get one and try to reverse engineer the circuit.
    Anyone got any hints ? Attached is what I was thinking of.
    bill.
    This should get you started with the ADC part. No LM358 required.
    http://www.rentron.com/PIC12C67XAD.htm
    Then once you have the ADC reading the pot, take the number generated by the ADC and use that with the PWM output.
    If you are using 8 bit the ADC will go from 0 - 255. Use a multiple of that number as the pulse.
    Feb 2003
    Sydney, Australia
    That bits no issue for me. Its the front end analog bit I am haviing the issue with.
    Hoped some analog hero would pop in with the solution !
    bill
    Maybe I am misunderstanding.
    Analog front end.
    The pot is connected between the ground and 5+ with the wiper going to the ADC input.
    The PWM output goes to the mosfet gate.
    The pot is not connected to the 10 volt. Use the same power supply as the PIC. The 10 V will only connect to the drain or source of the mosfet. NPN or PNP, what ever you use.
    you can still use your opamp directly.. the problem here is that your gain will never be 0.5 but 1.5.
    This bring at least few solutions. Forget the opamp, and use a simple voltage divider with 2 resistors + small capacitor (let's say 0.1uF) to smooth the signal noise...
    OR a more fancy op-amp circuit + low pass filter. the whole thing must have a gain of 0.5.
    Advantage to use an opamp in between... at least a higher input impedance... so you don't alter the signal.
    Which voltage sources you have on hand? Is there any negative rails?
    malc-c's Avatar
    malc-c Guest
    I would follow mister-e's suggestion and use a divider (2 x 10k resistors) to halve the voltage to give you the 5 volts and then feed this into the PIC.
    You could use the POT command to give you a value which is then used as the delay for the pulse train on the output, something like (I've not tried this but it should give you the idea)
    scale = 10
    Pot GPIO*,scale,D
    pwm GPIO.**,D,1
    Nah, sorry, not POT for me to measure an external voltage source. ADCIN (or home made ADC conversion routine) would be my suggestion.
    Maybe POT/RCTIME would be a last resort when your PIC don't have any spare ADCs and you need to measure a POT, maybe some LDRs... MAYBE.
    Feb 2003
    Sydney, Australia
    0-10v with a resistive 2:1 dividor would work for the 0-10v input to the ADC input. How about the pot input?
    The commercial units use a 10K between the ground and the input terminal (which can be either 10K pot or 0-10v), but i cannot figure out how they do it.
    Could it be a current rather than a voltage thing ??
    See - this is why I like digital stuff -its on or off.
    bill.
    malc-c's Avatar
    malc-c Guest
    True, but I have very limited experience of ADCIN
    With regards to the voltage divider the attached image might work - maybe better with a 10K lin pot ?
    Nope... range of 0-2.5 volts only... because this extra 10K in parallel with your POT.
    2x1% 10K in serie, your ADC in the middle... a 0.1uF cap and that's it.
    If the source handle this load, and is not that far of the PIC (i doubt because of this ol' 0-10v naming), this shouldn't cause any problem... as usual, software filtering/averaging are your friend.
    Looks Darrel had written something (LOL ) on that subject ... nooooooo ????
    http://www.pbpgroup.com/modules/wfse...p?articleid=25
    Boooooooooooooooooooooooooooo
    malc-c's Avatar
    malc-c Guest
    So how would he adjust the voltage, would placing the 10K pot across the 10v supply, and then placing the 2 x 10K resistors between the wiper and gnd, and then tapping off in the middle work. My thoughts would be that the tap in the middle of the resistors would therefore be half of what ever voltage is coming out of the wiper ?
  1. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:23
  2. 0 - 10V input on PIC 16F876
    By slayerizer in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 08:25
  3. Digital Pot Advice
    Last Post: - 22nd October 2007, 21:38
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Replies: 4
    Last Post: - 24th January 2007, 23:20
