MCLR line input only
Results 1 to 6 of 6
    Oct 2003
    Australia
    Unhappy MCLR line input only
    Hi guys,
    I made a monumental stuff up with a board I made using pin RA5/MCLR on a F88 chip. Problem is that I want to toggle this pin between LOW and TRISA.5 = 1. Normal state of the pin is set high (TRISA.5 = 1).
    After reading the data sheet it says this pin is input only, but surely, this pin can be driven low some how.
    Anyone care to put me out of my misery?
    Squib
    The data sheet tells the truth. Input only.
    Mar 2008
    Texas, USA
    Quote Originally Posted by Squibcakes View Post
    Hi guys,
    Well, at least you didn't order 1000 PCB's with RA5 used as an output.
    Hardware equivalent of Cut And Paste. Use a jumper wire to move the connection to a pin that can be bi-directional.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Don't feel bad, I've made this same mistake may times. You'd think I would actually remember it's only and input, lol.
    Sep 2007
    USA, CA
    It can be helpful to edit your pcb layout software to label the pin as input only.
    Oct 2003
    Australia
    Thanks guys, just as I suspected... Yep I'll have to cut the tracks and do some linking. At least it's only two pcbs. :-)
    Thanks for the tip Tenaja I'll do that.
    Squib
  1. Loop with two motor and 2 sensors
  2. Mclr As Input Pin?
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 07:33
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  5. 16f688 and MCLR (ra3) as input
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 1st March 2005, 19:15
