I've done it again
Results 1 to 17 of 17
    Some PIC may have ADCs or else fancy multiplexed stuff on this port. You want to make sure they're disabled first, unless you will have some erratic results.
    I usually use something a little bit different
    PORTC21Value=PORTC & 3
    IF PORTC21 =1 then ...
    if PORTC21=2 then ...
    IF PORTC21=3 then ...
    This read the whole PORT in oneshot and may override some RMW issue.
    Make sure you have any kind of pull-up / down resistor in case you're reading PushButtons
    <hr>
    There's nothing bad with PicFlash. You need to set your config fuses in your code and when you import the .HEX file, it will import/change the Config Fuses for you.
    You can lauch PICFlash in MCS. You need to add a programmer in the list. View>>Compile and program option>> programmer and folllow the instructions.
    I use the following parameters line
    -pPIC$target-device$ -f$hex-filename$ -e -w
    HTH
