The green stuff on a PCB
Results 1 to 34 of 34
    North Norfolk UK
    Hi Dave,
    Sorry I wasn't thinking with my practical hat on, I was just being anally retentive about my precious little tips
    if I cross contaminate the tips even with lead<>leadfree they simply will not "wet" properly I am probably doing something really wrong, maybe time to look at a hot air rework station they seem to be very popular. Although I just know that if I breathe on a 0402 I will never see it again Its getting to the point where I can't see them anymore I just hope I know where they are!!
    Duncan
    North Norfolk UK
    Hi Skimask
    oil burner for a furnace, burns oil at something like a billion degrees, they take used motor oil too.
    OMG I assumed my oil was being reprocessed recycled. How typically stupid. I can be so niave sometimes!
    anyway I am glad that I am not alone in some of my more bizarre habits of waste sorting.
    You lot over there are generaly a couple of years ahead of us, we (europeans) are just starting to deal with recycling but only through threats of massive fines and thats our governement being fined by some foreigner called Brussells!.
    So our local authorities are running around like headless chickens, literally.
    I referbed a old A3 printing heat press that had fluffy asbestos in it, so I phoned up the local council to ask them where I dispose of it, a few hours later and many transfers, I was eventually informed that there was "NO" facility available to members of the public in the county to dispose of it. They were terrified, no joke. I've still got it.
    I air out the aromatic organic solvents as much for my own sanity as for the environment
    Quote Originally Posted by duncan303 View Post
    I'm not even 100% sure that burning it at high temp's is good enough. Think of all the metallic contamination that's probably in there (especially if it came from a worn out motor). The guys at the HAZMAT shop said the costs involved with actually recycling oil are way too high, and you basically end up with the same problems anyways.
    I don't know about that. The gov't still hasn't switched over to lb-free soldering practices yet. In fact, it was only touched on in that micro-mini-circuit card repair class I went to last year. And if you look at all of the boards coming out of SE Asia these days, practically every one of them has lb-free markings on them.
    And again, as far as the HAZMAT guys are concerned, most commercially available products these days can be aired out without much worry. The main concern was the ozone depleting stuff (freon, etc). Good luck finding any of that these days.
    As far as the cross-contamination goes...In the shop, I've got 2 sets of stations, one set for lb-full and one set for lb-free. If I get any lb contamination on the lb-free tools, those parts go over to the lb-full station. So basically, when I need to buy stuff, I buy it for the lb-free work, and move it over when I screw up
    And, the instructors at that school said if you get lead into a lb-free environment, things get all screwy. You end up having to pump a load of heat into the product to get it to do anything for you...and by that time, you probably end up melting the PCB
    Jun 2007
    Mansfield, UK
    Im back home now. I cant find the laquer stuff. I know its here somewhere but with the state of this place at the moment i doubt ill find it soon. I do have my solder to hand though. Its "Lead free solder. Composition: SN 99.3% CU 0.7% 1mm diameter"
    Hi Duncan,
    I was not thinking about Pb free stuff. I am still a 60/40 type But Pb is the least of my worries. At my day job, one of my duties is heading up our HAZWOPER team. That stands for Hazardous Waste Operations and Emergency Response. Mostly the emergency response part.
    As far as your waste disposal goes, sounds like you are "OK".
    One thing I have heard about waste oil, and I do not know if it is true. It gets hauled to the cost and loaded on a ship. Once past the twelve mile limit a valve is turned. Now it is a fuel.
    Hi Duncan,
    That is what the recycler told me too . .
    North Norfolk UK
    Hi Dave
    AAAArggghh. Just goes to show what a massive problem it is for all of us..
    My 5 Gall drum is about 1/2 full, but there are some empty 100gal barrels I could start using. Not a solution I know. maybe I am making matters worse by combining, I should look at the COSH sheets and see if I can grade the waste and maybe I should deal with the tin plating separately.
    Hi Skimask
    We eventually had ROHS April last, and such a build up.... every other conference or article was about it. Now you hear practically nothing!
    How did it impact me, well I tried to get my BOM lists done early at least 12 months, by the Date I only had one component NON-ROHS( subsequently designed out), which I thought was pretty damn good, it was helped by good support by suppliers, one of the first to make it easier was Farnell who is Newark for you, they seemed to be the first to allow a set global search preference of ROHS only, and then introduced "good" alternative suggestions to all search results.
    Vishay amongst others caused a big problem with all its rebranding nonsense and nobody knew either where the datasheets were or verified ROHS or not, that was the biggest problem really, finding reliable alternatives.
    I have sub assemblies come in from Shenzen, hands up I admit it (no choice), and they could'nt have left it closer to the mark. And I got left with a RoHS unverified order , cheers guys, hope the games go well.
    I use digi-key and they have had the RoHS combo box for a long time, no doubt they will start to offer more services as the date approaches.
    Having said all that, the transition appears to have been pretty smooth, still a lot of tight lipping to some subjects, a sort of wait and see policy. Who is going to get prosecuted first and exactly what for. To *******ise a quote from this forum "if anybody is actually going to appear at the door armed with anything more than a digital fridge thermometer........"
    So it really comes down to two areas manufacturing vs hobby, as long as you do not place a particular product "on the market", you can do pretty much as you please, therefore all prep DFM work can be as hazardous as you wish, but you cannot sell (or in my opinion give) anything non compliant to any other person.
    So making a nice enticing hobby non-rohs led flashing christmas decoration that a little baby is going to want to put in its mouthand suck, seems to still be fine.
    Perhaps they should adopt the same policy for heroin addicts and just let them have as much heroin as they want, when they want, as long as the do not give it away or sell it, Big problem solved!
    On the bench, lead free soldering has all its associated difficulties, at first there was no alternative. Brussels left it up to manufacturers and market demand to provide a lead free solder that people could actually use so loads and loads of test samples became available as giveaways, and it all became great copy in the periodicals. For me I have piles of samples enough to keep me going probably for years, I tend to choose any one that has the highest silver content, purely personal. But improved "solderability" is gradually being addressed in other areas, pcbs come back gold HSL etc. so by the time you have to set up to the plate things could be a little easier.
    I still cannot sculpt lead-free as well as leaded (rosin and colophony free) so I may use leaded for amendment prototyping, lead-free is so fragile especially when you are adding unsupported components and the board is getting a lot of handling. Same as you Skimask any contaminated tips get relegated.
    One thing I do on production boards which I haven’t seen anywhere is pre clean a length of solder with isoprop and then only handle and feed with lint free glove, my other glove is an unpowdered latex.
    In the service and repair industry for goods previously on the market I recall it as being like for like, how much that is adhered to is anybodies guess, what still is unresolved is that if I want to use say a TDA series and sell it as part of an in-car product it is NON-RoHS, otherwise it is RoHS.
    Generally Medical, Military and Motor are exempt. I can understand nobody really taking much notice if the tomahawk approaching you has been verified RoHS, but I do wonder about spending an hour or so inside a hot NMR scanner. Of course the motor manufacturers are exempt because……….err mmmmm….
    cos we all need to err……?
    Duncan
    North Norfolk UK
    Hi Duncan,
    have had a reply
    Dear Duncan
    Thank you for your query regarding engine oil recycling. I have also
    received a telephone message. Apologies for the delay in reply, I have
    been away on leave.
    Used engine oil is collected from all of our 19 recycling centres by a
    company called Malary Oils.
    Most oil recycling companies use a similar process. Once the oil is
    collected it is taken for testing. Dependant on it's quality some of it
    will be sent for disposal (which will either be incineration or a
    hazardous landfill site) and the rest can then be reprocessed. During a
    slow heating process water is separated from the oil. The water then
    goes to a water treatment facility. The oil is then filtered and acts as
    fuel for high temperature combustion furnaces and boilers.
    I hope that this information is of use. Please do not hesitate to
    contact me should you have any further enquires.
    Not too bad a reply, suppose its landfill vs international waters then.
    I think I might delve further and see if the criteria for incineration/landfill is degree of contamination.
    ____________________
    __________________________________
  1. Gerber - PCB Layout Software??
    By kevj in forum General
    Last Post: - 3rd April 2013, 07:51
  2. LEDs schematics
    By saturnX in forum Schematics
    Last Post: - 29th July 2008, 02:13
  3. Master to slave 16F767
    By sachymo in forum General
    Last Post: - 3rd June 2008, 21:22
  4. Replies: 0
    Last Post: - 14th April 2007, 07:17
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
