Please help...
Results 1 to 17 of 17
Thread: Please help...
Threaded View
    Mar 2008
    Default Please help...
    I've done a stupid thing, I'm trying to learn how to program PIC's and thought I was doing well by getting a copy of PicBasicPro
    All every well, then I needed someway of programming the pic to try it out, so me being a smartass went and got the EasyPic5 development board as it included sockets for various Pic's and also came with a 2 X 16 LCD
    Great board, but it uses MikroBasic and unless you spend another £99 your limited to 2k in your program....ARGHH
    I Hate MikroBasic!
    I've been trying to get this working (untill I can sell the easypic5 board) by writing and compiling the program in PBP and then programming the pic on the easypic board by using the programming software that came with it
    btw if anyone wants an almost new Easypic5 board, contact me, it's going cheap and only used for this one thing!
    This SEEMS to work fine, but I've a problem.
    Going back to basics, I've tried writing the "Hello World" program, it compiles fine, seems to load fine but just wont display anything on the pic
    The Pic is a 16F677A with an 8Mhz xtal
    The LCD is connected on the board as follows:
    RS RB4
    RW Vss/Ground/0V
    E RB5
    D7 RB3
    D6 RB2
    D5 RB1
    D4 RB0
    Here is my code:
    'LCD DEFINATION*****************************************************************
            DEFINE LCD_DREG PORTB       ' Set LCD Data port
            DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus i.e, PortD.4-PORTD.7
            DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
            DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit i.e, PORTC.5
            DEFINE LCD_EREG PORTB       ' Set LCD Enable port
            DEFINE LCD_EBIT 5           ' Set LCD Enable bit i.e, PORTE.4
            DEFINE LCD_BITS 4           ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
            DEFINE LCD_LINES 2         ' Set number of lines on LCD to 4 Lines
            DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
            DEFINE LCD_DATAUS 50        ' Set data delay time in us
                         Pause 500       ' Wait for LCD to startup
    loop:   Lcdout $fe, 1   ' Clear LCD screen
            Lcdout "Hello"  ' Display Hello
            Pause 500       ' Wait .5 second
            Lcdout "World"
            Goto loop       ' Do it forever
    What Am I doing wrong? I'm sure its something really stupidly simple but I've spent so much time on this its frying my brain!
    The board and LCD both work fine, I know because I've loaded several of the samples written already in Mikrobasic such as the one showing the lcd working and the temperature readout using the DS1820 both work fine.
