On the 16F family of chips, these do the same as
clrf TRISB
movwf ADCON1
IMHO, they (yours above) are just written using crispy-clean style ... on the 16F chips the operands for both of these instructions are limited to 0x00-0x7F(see data sheet). The clrf statement you listed clears the 8th bit ... but only the first seven bits are read anyway. The movwf toggles (in this case clears) the 8th bit, but again only the first seven are used by the command.
I believe this once common crispy-clean style was used to ensure possible upwards compatibility with future chips ... the future chips like the 18F and beyond have changed how they deal with SFRs so you do not see this style very often.
HTH
