plaese help explain such statement ABYTE.0[Index]=0, what is that mean
Results 1 to 9 of 9
    Apr 2008
    Smile you are so kind
    While not offering any detail, the Repeat statement in the manual does demonstrate it.
    I have the pbp manual , different version with you? I can not found the statment "repeat", while I found the word in it : )
    1.2. About This Manual
    This manual cannot be a full treatise on the BASIC language. It
    describes the PicBasic Pro Compiler instruction set and provides
    examples on how to use it.
    I have an ol' version of the manual.. for compiler version 2.47 (date 9/05). REPEAT is located in section 5.66
    But yeah... it show they use it... but they don't explain anything
    Online version show date 3/04, Repeat is still at 5.66, same... everything.
    I didn't check the whole manual.. but here's my understand.. i'll do it once
    It's nothing more than another kind of fussy writing thing. Which perform some kind of text substitution thingy.
    YourVar=4
    Something.0[YourVar]=1
    becomes Something.04=1
    That's the easiest way i see to explain it... but yeah.... why it's like that? ... because
    Perth, Australia
    I'm not sure why they didn't just allow you do use VAR.BIT=0 instead of VAR.0[BIT]=0.
    What would be nice is to be able to also do this: VAR[INDEX].BIT=0
    I came across a situation just yesterday that required me to set a bit in a word, in an array to the same as another bit in another word in another array, so if it was allowed would be like this:
    VAR1[INDEX].BIT=VAR2[INDEX].BIT
    Instead of one line like above, it ended up being 5 lines.
    No matter tho, theres always a way around these things.
    Apr 2008
    Default you are all so kind
    you are all so kind
  1. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 02:09
  2. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:48
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. getting around the basic IF - THEN statement
    By dw_pic in forum mel PIC BASIC Pro
    Last Post: - 7th February 2006, 15:10
