Good Question !!!
NO the two timers can't start ( or stop ) at exact same moment ... due to Pic working way !
BUT you can preload the second ( or third...or ...) timer to get a correct value ...
Good Question !!!
hi
I might think about placing T0CON.7=1 and T1CON.7=1 on consecutive lines, depending on your clock you can calculate the instruction cycle delay and calibrate that into your calculationshow can I modify my code to ensure that both timers start and stop EXACTLY at the same time
Depends how "Exactly" fits into your frame of reference, you are measuring pulses on both timers, therefore the difference will always be a constant and you could correct it as a standard systematic error.
Others will probably know of a way to reduce the delay further than I have suggested but ultimately I suggest it depends on the PIC itself.
Does the datasheet give a method of starting two timers with the same instruction?
Just a thought
Duncan
Oh hell
I am always getting logged out when trying to write a contribution, I know I am slow..... but this is tooooo much.
Anybody know of a setting for "old gits"
or should I just take the hint and simply give up
at second sight ...
You have two "capture" modules in a '252 ...
WHY not use both ... triggered at the SAME time ...
Hi Alain
MmmmYou have two "capture" modules in a '252 ...
Although the "event" trigger would take place at a specific time, would there not be a problem stopping the timers?. Surely they cannot be stopped at the "same "time. One has to take priority over the other, by at least one instruction cycle if not two, one for the capture and a second for the stop.
Maybe then three cycles for the second timer (extra cyle whilst waiting for the first to be stopped.)
As mentioned.... how exactly is Exactly?
Just random thoughts
Duncan
Hi, Duncan
This is the same question as " I want to measure the 100th of degree with a LM35 and VDD ref " ...
99 times upon 100 ... no real need ... exept "for the show" ... but 1% remain useful ...
but, good exercise to have a reflexion about what offers the chip as features ...
your are quite right Alain.but, good exercise to have a reflexion about what offers the chip as features ...
I have taken a very big step away from the bench for a while now, (just can’t seem to get the level of concentration back).
There are so many ways of achieving a result that sometimes I have had difficulty seeing through the “liminal”. And by that I mean the mental area where I can unnecessarily execute a task in PBP that can be completed very simply using the inbuilt features of a PIC, and Visa-versa
Approaching a problem from a PIC perspective or PBP Perspective. And I haven’t started on peripheral components.
So it is really valuable to have a reflection
I am in a mental state where I am looking at code and circuits and simply cannot believe they are mine, what they are for and why I build them in the first place. I am finding it quite depressing.
Anyway, I am hijacking a thread again, so back to it,
On a 252 I might set an interrupt on the two comparators (single interrupt only inbuilt I think) for each channel that I wish to monitor and use that interrupt event to start one timer with a preload and interrupt on overflow…..Whilst……. using the other two CCP and associated timers to capture all the events on the two channels.
So I might have THREE consecutive lines starting each of the three timers, just as Alain suggested
If the events on the two CCP channels are very close together and are triggered before the reset/write is completed then consider a PIC with more Timers that can be associated with the CCP’s so that each subsequent trigger on a particular channel uses a different timer.
Is every edge being triggered (random pulses) or is it looking at a frequency. So much of this is application specific.
Duncan
