Newbie has some questions
Results 1 to 40 of 44
Threaded View
  1. #30
    Nov 2004
    Saskatchewan Canada
    Now I want to tackle the bitwise AND & syntax.
    I think I am clear now on how we've come up with our 16 bit WORD seeds and what not.
    For this example it is W0=%0000000011101101
    When something like this is done:
    <b>randomlight=W0 & $000F</b>
    it is also like saying:
    <b>randomlight=W0 & %1111</b> correct?
    It is comparing the first four bits of the word so it looks like this:
    <b>%0000000011101101</b> - original word
    <b>%0000000000001111</b> - AND compare on bitlevel (narrow it down to 16 or less)
    <b>%0000000000001101</b> - result of the compare
    No matter how you compare with the second set of bits the results is the first four bits of the first set. The "&000F" is just a handy way of stripping away the bits that aren't needed?
    My result comes back as a decimal 13 in this case.
    But if I do it wanting to pick from 15 lights instead:
    <b>%0000000000001110</b> - AND compare on bitlevel (narrow it down to 15 or less)
    <b>%0000000000001100</b> - result of the compare
    Decimal 12
    If I wanted to I could compare any number of bits by adjusting the second row of numbers so I could use & %00FF to come up with:
    <b>%0000000011111111</b> - AND compare on bitlevel (narrow it down to 255 or less)
    <b>%0000000011101101</b> - result of the compare
    Decimal 237
    <b>%0001011011101001</b> - original word
    <b>%0000000011111110</b> - AND compare on bitlevel (narrow it down to 254 or less)
    <b>%0000000011101000</b> - result of the compare
    Decimal 232
    The only problem here is that I don't see where the results are <em>seldom</em> different in the final row than what the original first few bits in all the examples I also did on paper unless the second row has lots of zeros compared to the first row so I think I am missing a key point?
    It is getting a little confusing now understanding the exact function of bitwise AND. Can someone expand to fill in the gaps here?
    Am I, at least, close on this operation?
    Thanks.
    Bart
  1. Olympic Timer
    Last Post: - 17th September 2008, 19:46
  2. Analog port newbie questions
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 11:38
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 09:56
  4. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 22:24
  5. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
