base64 encoding
Results 1 to 9 of 9
Thread: base64 encoding
    Jan 2007
    Default base64 encoding
    Hello,
    has anyone the idea, how to do base64 encoding of the short string? I need it to encode the e-mail username and password...
    Perth, Australia
    I would take your input array of bytes and using a simple loop, create an array of bits.
    Then using a second loop, read those bits 6 at a time and use a combination of math and a lookup table to generate the output.
    The wikipedia article on Base64 has a lot of useful info, including C code for encoding and decoding:
    http://en.wikipedia.org/wiki/Base64
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Perth, Australia
    Was bored, so I figured i would give this a shot.
    Untested, so try at your own risk
    STRING_LENGTH   CON 24 ; Must be divisable by 3
    in_string       VAR BYTE[STRING_LENGTH]
    in_byte         VAR BYTE
    in_bit          VAR BYTE
    b64_string      VAR BYTE[STRING_LENGTH*4/3]
    b64_byte        VAR BYTE
    b64_bit         VAR BYTE
    temp            VAR BYTE
    in_byte=0                                               ; Start at byte 0
    in_bit=7                                                ; Most significant bit first
    FOR b64_byte=0 TO (STRING_LENGTH*4/3)-1                 ; For each base64 byte:
        b64_string[b64_byte]=0                              ; Clear the byte
        FOR b64_bit=5 TO 0 STEP -1                          ; For each bit 5 thru 0:
            temp=in_string[in_byte]                         ; Get the current input byte
            temp=temp >> in_bit                             ; Shift to get the current bit as bit 0
            temp=temp & 1                                   ; Clear the other bits
            temp=temp << b64_bit                            ; Shift to the correct output bit position
            b64_string[b64_byte]=temp|b64_string[b64_byte]  ; Add the bit to the base64 byte
            in_bit=in_bit-1                                 ; Next less significant bit
            IF in_bit=255 THEN                              ; If we past bit 0:
                in_bit=7                                    ; Set to bit 7 of the next byte
                in_byte=in_byte+1
        NEXT b64_bit
        SELECT CASE b64_string[b64_byte]                    ; Convert to base64 coded ASCII
            CASE IS<=25                                     ; 0-25
                b64_string[b64_byte]=b64_string[b64_byte]+65; "A"-"Z"
            CASE IS<=51                                     ; 26-51
                b64_string[b64_byte]=b64_string[b64_byte]+71; "a"-"z"
            CASE IS<=61                                     ; 52-61
                b64_string[b64_byte]=b64_string[b64_byte]-4 ; "0"-"9"
            CASE 62                                         ; 62
                b64_string[b64_byte]=43                     ; "+"
            CASE 63                                         ; 63
                b64_string[b64_byte]=47                     ; "/"
        END SELECT
    NEXT b64_byte
    Boban, which PIC you plan to use?
    Who's interested to participate to a "convenient and ease of use routine" contest ? Just for fun though...
    No one?
    i had a 1/2 hour to kill so i did this one. No matter if your string is dividable by three or not, the software will adjust it. I've compare my results with the following online converter tool
    http://makcoder.sourceforge.net/demo/base64.php
    Everything seems ok. Personnal and deliberate decision from myself to remove the comments... oh i'm a monster
    You just need to figure out
    This assume your PIC have a 256 bytes EEPROM. I used a dusty F877
    <font color="#000000">        @   __CONFIG _HS_OSC &amp; _LVP_OFF &amp; _WDT_OFF
            <font color="#000080">DEFINE </font>OSC 20
            <font color="#000080">DEFINE </font>HSER_RCSTA 90h <font color="#008000">' Enable serial port &amp; continuous receive
            </font><font color="#000080">DEFINE </font>HSER_TXSTA 24h <font color="#008000">' Enable transmit, BRGH = 1
            </font><font color="#000080">DEFINE </font>HSER_SPBRG 129 <font color="#008000">' 9600 Baud @ 20MHz, 0.16%
            </font><font color="#000080">DEFINE </font>HSER_CLROERR 1 <font color="#008000">' Clear overflow automatically
            </font>Len             <font color="#000080">VAR BYTE
            </font>ByteA           <font color="#000080">VAR BYTE
            </font>buffer          <font color="#000080">VAR BYTE</font>[3]
            Encoded         <font color="#000080">VAR BYTE</font>[4]
            EncodedCounter  <font color="#000080">VAR BYTE
            </font>CounterA        <font color="#000080">VAR BYTE
            </font>CounterB        <font color="#000080">VAR BYTE
    </font>String1     <font color="#000080">DATA </font>&quot;Man is distinguished, not only by his reason, but by this singular passion &quot;<font color="#008000">;from other animals, which is a lust of the mind, that by a perseverance of delight in the continued and indefatigable generation of knowledge, exceeds the short vehemence of any carnal pleasure.&quot;
    </font>String2     <font color="#000080">DATA </font>0
    BASE64Table <font color="#000080">DATA </font>@191, &quot;ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=&quot;
            Len = String2 - String1
            <font color="#000080">IF </font>(Len//3) <font color="#000080">THEN
                </font>ByteA=3-(Len//3)
                <font color="#000080">FOR </font>CounterA=0 <font color="#000080">TO </font>(ByteA-1)
                    <font color="#000080">WRITE </font>(Len+CounterA),0
                    <font color="#000080">NEXT
                </font>Len=Len+ByteA
                <font color="#000080">ENDIF
            HSEROUT </font>[&quot;Len=&quot;,<font color="#000080">DEC </font>Len,13,10,_
                     &quot;Original string&quot;,13,10]
            <font color="#000080">FOR </font>CounterA=0 <font color="#000080">TO </font>(Len-1)
                <font color="#000080">READ </font>CounterA,ByteA
                <font color="#000080">IF </font>ByteA <font color="#000080">THEN
                    HSEROUT </font>[ByteA]
                NEXT
            HSEROUT </font>[13,10, &quot;Encoded String&quot;,13,10]
            EncodedCounter=0
            <font color="#000080">FOR </font>CounterA=0 <font color="#000080">TO </font>(Len-3) <font color="#000080">STEP </font>3
                <font color="#000080">READ </font>CounterA, buffer[0]
                <font color="#000080">READ </font>(CounterA+1), buffer[1]
                <font color="#000080">READ </font>(CounterA+2), buffer[2]
                Encoded[0]=buffer[0]&gt;&gt;2
                Encoded[1]=((buffer[0]&amp;3) &lt;&lt;4) | (buffer[1]&gt;&gt;4)
                <font color="#000080">IF </font>buffer[1] <font color="#000080">THEN
                    </font>Encoded[2]=((buffer[1]&amp;$0F)&lt;&lt;2) | (buffer[2]&gt;&gt;6)
                    <font color="#000080">ELSE
                        </font>Encoded[2]=64
                IF </font>buffer[2] <font color="#000080">THEN
                    </font>Encoded[3]=buffer[2] &amp; %00111111
                        </font>Encoded[3]=64
                </font>EncodedCounter=EncodedCounter+4
                <font color="#000080">FOR </font>CounterB=0 <font color="#000080">TO </font>3
                    <font color="#000080">READ </font>(Base64Table+Encoded[CounterB]),ByteA
                    <font color="#000080">HSEROUT </font>[ByteA]
                NEXT
            STOP
    </font>
    There's load of room for improvement. At least it works!
    There's still the "convenient" part to do... if really needed and asked.
    Perth, Australia
    Touché
    Perth, Australia
    Do you mean:
    Personal and deliberate decision from myself to be lazy and not write any comments in the first place.
    :P
    mmm time saving... maybe true
    Jan 2007
    Default Sorry for the late response
    Cus, I am very soory for the too late delay, I have a lot personal stuff to do and didn't had time for the playing.I see, that you have spent a lot of time to do it, it is nice inspiration for me to use your code. Thans a lot - it is both of you!!!
  1. HSERIN and STR - character encoding
    By boban in forum mel PIC BASIC Pro
    Last Post: - 13th August 2008, 17:36
  2. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 13:31
  3. Manchester encoding
    By jonathanRF in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 19:05
  4. Manchester encoding
    By jonathanRF in forum Off Topic
    Last Post: - 8th February 2007, 18:56
  5. Turbo Encoding with Pic Basic Pro
    By obaskirt in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 09:22
