Code snippet: time execution for each line: help please
Results 1 to 2 of 2
    There's few way to measure it
    a) Toggle a led between a code snip, and mesure it with a scope
    b) using MPLAB stopwatch
    c) using the following method
    http://www.picbasic.co.uk/forum/show...72&postcount=2
    and if you want to elaborate a bit more
    http://www.picbasic.co.uk/forum/show...33&postcount=9
    If you're using the above solution with Timer, don't forget to adjust your results with Timer ticks.
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Making Program Code Space your playground...
  3. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
  4. Line following robot... problems with some code
    By nepstar in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 02:10
  5. Time diference in microseconds
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 09:25
