I2C write - value too big
Results 1 to 20 of 20
    Hello sayzer, Mister-e and Acetronics
    1. You have two "goto" s one after the other. When the first one runs, the second one will not run!
    this is true. I sampled this section from the hole code to test your help but there are some " ' " missing there.
    However, removing the missing links and compiling errors the final result is the same.
    I2CREAD SDA,SCL,CTW,ADDR.highbyte,addr.lowbyte,[tempe]
    Why do you split addr in 2 ?
    I2CREAD SDA,SCL,CTW,ADDR,[tempe]
    This have to be changed in ALL I2CREAD AND I2CWRITE lines
    This is my biggest problem. What you suggested was my first written code and it didnt worked.
    This was my problem in the past and resolved with the help of Skimask.
    (see post...)
    http://www.picbasic.co.uk/forum/showthread.php?t=8153
    Frankly,i didnt understood then as i still dont now, but it worked.
    The problem now is that it's not returning good values after the 127 mark and i believe that it's related with 1111111 going to 10000000 since that i read nothing but 000.x from there.
    ( see attached pic )
    Well, i think i just fixed one problem and found a new one
    I have sucessfuly use the code " I2CREAD SDA,SCL,CTW,ADDR,[tempe] ".
    After several changes i tryed Mister-e's suggestion and removed the OSCTUNE=0 line.
    It doesnt make sense to me ( or does it ? ), but it's working this way now.
    The new problem that i found is that while debugging i found out that the problem related with getting low values passed the 120'ich mark IS NOT related with the eeprom/low-highbytes.
    I got a variable resistor to simulate the LM35 and was changing the value while recording, and i could see that the value captured dropped after the conversion and before recording to the eeprom.
    this is the capture while increasing the variable resistor
    111,3
    111,8
    112,3
    112,3
    112,7
    112,7
    113,2
    113,7
    114,2
    114,7
    115,2
    115,7
    116,2
    117,6
    118,1
    118,6
    118,6
    118,6
    118,6
    119,1
    121
    121,5
    122
    122,5
    122,5
    122,5
    122,5
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    now i'm lost
    Hi, Ruicj
    Can you tell us how you get those values :
    ( 122.5 is NOT a PbP value ...)
    - Input value range ( volts ? ) / ref voltage
    - Math used ( in PbP )
    - Values you want to to output
    It's "not so clear" ...
    PS : ANSEL doesn't match the ADCIN PORT !!! Check it !!!
    Hello Acetronics,
    these values i get from:
    FOR ADDR=st TO ed
       		adcin temp,va
    tempe=(va*/5000 )>>2
            toggle red
            toggle green
            pause   418    ' calibration to get  1200  readings  ( 2 per second ) in 10 minutes   -
            debug " recorded value: ", dec tempe," position  ", dec ADDR, 13,10
    the debug line gave these values after the adcin conversion.
    I'm colecting the voltage directly from the variable resistor which is simulating the voltage from a LM35 ( 0,2v - 1,5V )
    I'm not using any reference value, just VDD and VSS( i know...it's lame...but i'm not looking for the best resolution for now )
    seen it ???
    ANSEL select A1 and A2
    ADCIN select A0 ...
    Acetronics,
    You are right !!! Thank you ( and the rest of the guys for the help )
    This was set when i was playing with several sensors
    But how can it be ?? If i have the ANSEL with a different channel, how can i get values on channel A0 ??
    This is why i didnt see it
    Wink
    Capacitive coupling ... pins are side-by-side !!!
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Replies: 5
    Last Post: - 29th May 2008, 19:03
  4. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
