I2C write - value too big
Results 1 to 20 of 20
    Just use:
    I2CWRITE SDA,SCL,CTW,ADDR,[TEMP]
    This was my first option, but for some reason the eeprom does not store the data this way.
    Actually, with the 12F675 chip this eeprom works well with :
    I2CWRITE SDA,SCL,CTW,ADDR,[temp.highbyte]
    pause 10
    ADDR=ADDR+1
    I2CWRITE SDA,SCL,CTW,ADDR,[temp.lowbyte]
    But not with the 16F88.
    I got it working with :
    I2CWRITE SDA,SCL,CTW,ADDR.highbyte,addr.lowbyte,[tempe]
    pause 10
    ADDR=ADDR+1
    The problem now is for the lenght of the tempe value when over 125ºC
    something don't make sense... could you post your whole code for the 16F88?
    Here's the code:
    OSCCON  =  $7e  'Internal RC w/ I/Os
    CMCON = 7      'comparators off
    CVRCON = 0     'Vref Off
    CCP1CON=0
    T1CON  = 0
    OSCTUNE=0
    'DEFINEs
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE PROTECT_OFF
    DEFINE OSC 8
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    'ADC
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    'ADC parameters
    ADCON1  =%10000000      'right justify
    ANSEL   =%00000110
    ADCON0  =%11000001
    INCLUDE "modedefs.bas"
    DEFINE debug_reg PORTA
    DEFINE debug_bit 1
    DEFINE debug_baud 9600
    DEFINE debug_mode 1
    ' variables
    va       var word
    tempe    var word
    mem      var word
    state    var byte
    st       var word
    ed       var word
    ADDR     var word
    m1       var word
    m2       var word
    m3       var word
    m4       var word
    slot     var byte
    w        var byte
    RA       var word
    x        var word
    ps1      var word
    ps2      var word
    ps3      var word
    ps4      var word
    temp1   var tempe.highbyte
    temp2   var tempe.lowbyte
    rm con 8
    ps1=1
    ps2=4
    ps3=7
    ps4=10
    p1a  con $10
    p1b  con $e20
    p2a  con $e2a
    p2b  con $1c3a
    p3a  con $1c44
    p3b  con $2a54
    p4a  con $2a5e
    p4b  con $386e
    'CLEAR
    ctw CON $A0
    PORTA=0
    PORTB=0
    TRISA=%00100101
    TRISB=%00001111
    'PINS
    temp      var PORTA.0
    out       var PORTA.1
    volt      var PORTA.2
    a3        var PORTA.3
    jumper    var PORTA.4
    but1      var PORTA.5  'read
    led2      var PORTA.6
    led1      var PORTA.7
    but2      var PORTB.0  ' record
    p1         var PORTB.1
    SCL       var PORTB.2  ' eeprom
    SDA       var PORTB.3  ' eeprom
    green     var PORTB.4  ' bicolor led (green)
    red       var PORTB.5  ' bicolor led (red)
    led4      var PORTB.6
    led3      var PORTB.7
    startmenu:
    st=p1a
    ed=p1b
    if but1=1
    While but1=1
    Wend ' Wait here for Button to be released
    gosub readmenu
    if but2=1
    While but2=1
    gosub recordmenu
    goto startmenu
    readmem:
    led2=1
    led3=0
    'debug "Reading Memory",13,10
    'debug "Address: ",dec mem," start at ",dec st, " and finish at ",dec ed,13,10
    'debug " Memory # ",dec mem,13,10
    FOR ADDR =st TO ed
    toggle led2
    toggle led3
            I2CREAD SDA,SCL,CTW,ADDR.highbyte,addr.lowbyte,[tempe]
            PAUSE 10
            toggle green
    debug dec3 tempe/10,",",dec1 tempe//10,13,10
            ADDR=ADDR+1
            NEXT
            green=1
    FOR ADDR=st TO ed
       		adcin temp,va
    tempe=(va*/5000 )>>2
            toggle red
            toggle green
            pause   418    ' calibration to get  1200  readings  ( 2 per second ) in 10 minutes   -
            debug " Valor Gravado: ", dec tempe," Na posição  ", dec ADDR, 13,10
            pause 10
            ADDR=ADDR+1
            I2Cread SDA,SCL,CTW,mem.highbyte,mem.lowbyte,[x]
            pause 10
            'debug "Address: ",dec mem," started at ",dec st, "finish value ",dec x,13,10
            debug "  ",13,10
            if but1=1 then      'stop recording
            pause 600
            goto timing
            goto startmenu
            NEXT
            red=1
    Jan 2006
    Istanbul
    Ruijc,
    I did not check the code in detail but at first look there is something that should not be done.
            goto timing
            goto startmenu
            NEXT
            red=1
    1. You have two "goto" s one after the other. When the first one runs, the second one will not run!
    2. When the first one runs, then you will have a return address on stack; Thus, the next time you hit a return, where ever it is, it will ruin your logic flow. You must organize a logic flow that will clear the return address of the subroutine you are in. Example: set a flag and then exit the subroutine with "return".
    i'm a bit surprised you don't have any compilation errors...
    a) 2 mistyped IF statements,
    b) it miss Readmenu, recordmenu, timing section,
    c) and as Sayzer point-out.. those goto are a bit weird... and in case you remove Goto timing... it will branch to the startMenu indeed... but you will always add 1 on the Stack.. shortly it will overflow...
    OSCTUNE=0
    why? You don't need to do it unless you want to calibrate the internal OSC, just remove it. Almost sure your Serial comm wasn't working really well huh? (DEFINES aren't in caps either.. but it can be a paste error)
    Why do you split addr in 2 ?
    I2CREAD SDA,SCL,CTW,ADDR,[tempe]
    This have to be changed in ALL I2CREAD AND I2CWRITE lines
    This must be written the right way.. unless YOU will have problem indeed.
    Lightbulb
    I wonder the '675 was running @ 4Mhz , the '88 is running @ 8Mhz ... which is the limit for using " I2C SLOW" ...
    Did you try that DEFINE ???
    Just an idea ...
    Not a problem for the 24LC512 unless the pull-up resistor are way to high... it can run up to 400KHz, 1MHz for FC version.
    But there's few mistakes in the code.... sure i missed a few
    Hello sayzer, Mister-e and Acetronics
    this is true. I sampled this section from the hole code to test your help but there are some " ' " missing there.
    However, removing the missing links and compiling errors the final result is the same.
    This is my biggest problem. What you suggested was my first written code and it didnt worked.
    This was my problem in the past and resolved with the help of Skimask.
    (see post...)
    http://www.picbasic.co.uk/forum/showthread.php?t=8153
    Frankly,i didnt understood then as i still dont now, but it worked.
    The problem now is that it's not returning good values after the 127 mark and i believe that it's related with 1111111 going to 10000000 since that i read nothing but 000.x from there.
    ( see attached pic )
    Well, i think i just fixed one problem and found a new one
    I have sucessfuly use the code " I2CREAD SDA,SCL,CTW,ADDR,[tempe] ".
    After several changes i tryed Mister-e's suggestion and removed the OSCTUNE=0 line.
    It doesnt make sense to me ( or does it ? ), but it's working this way now.
    The new problem that i found is that while debugging i found out that the problem related with getting low values passed the 120'ich mark IS NOT related with the eeprom/low-highbytes.
    I got a variable resistor to simulate the LM35 and was changing the value while recording, and i could see that the value captured dropped after the conversion and before recording to the eeprom.
    this is the capture while increasing the variable resistor
    111,3
    111,8
    112,3
    112,3
    112,7
    112,7
    113,2
    113,7
    114,2
    114,7
    115,2
    115,7
    116,2
    117,6
    118,1
    118,6
    118,6
    118,6
    118,6
    119,1
    121
    121,5
    122
    122,5
    122,5
    122,5
    122,5
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    0,4
    0,9
    now i'm lost
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Replies: 5
    Last Post: - 29th May 2008, 19:03
  4. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
